Number of Voice Messages
JustForVoice_2
Level 4
Level 4
Hi everybody,
Is there any way to show the number of messages in my voicemail on my phone screen? like beside the envelop 4 or 5 messages. ot any other method?
Jonathan Schulenberg
This is called Enahanced MWI (eMWI) and is supported by current versions of Unity Connection. It can be enabled under the Phone System integration. So far only the 8900/9900 series phones have added support for displaying the eMWI message count though. The 7900 phones still only display the envelope.
Rob Huffman
Hey JFV,
Just to add another option to the great tips from Jonathan (+5 "J-man")
You might want to look into Visual Voicemail (a widget that runs with Unity Connection)
http://www.cisco.com/en/US/docs/voice_ip_comm/cupa/visual_voicemail/8.5/release/notes/vivoReleaseNote85.html
Cheers!
Rob
Thank you too much for your reply and sorry to reply just now
+5 for both
