Reporting for Contact Centre
dimple mujoo
Customer is trying create custom reports for their call center, however they prefer to do this using the data directly from the Database server, rather than CUIC.
any idea how do we obtain the Raw data, any documentation?
Deepak Rawat
https://supportforums.cisco.com/document/64301/squirrel-sql-client-setuppdf
Once you have access to the UCCX DB following above, then it is up to you how to use the data and create Custom Reports
Deepak
they are on 10.x
Does not matter, process is the same
Deepak
