Restore UCM 9.1.2
Dear Friends,
I want to rebuild the complet host (UCS 220M3) considering UCM. Can I do a backup using veeam backup or data protector software on vmware in order to rebuild my UCM too. I just did an export to OVA by deploy and it failed. Can I monitor my UCM by Zabbix software?
I have a UCM 9.1.2 on vmware.
Thanks in advance,
Claudio Quiroz C - Latam
Jaime Valencia
Officially we only support DRS, you could simply copy the files from your CUCM out of the server and then place them back once you rebuild your ESXi, I need it to be completely clear that although that method would work, is not officially supported by Cisco. It would be the equivalent of a cold migration from a server to another without vCenter.
java
if this helps, please rate
Jaime Valencia
java
Good Jaime,
I have a doubt: Can I monitor the UCM on vmware, using Zabbix software?
I'm not familiar with that SW, generally the 3rd party is the one that does compatibility testing, you probably want to reach Zabbix, if it involves having to install something in the server, then that's really easy, the answer is no.
java
