RTMT alert for PRI
Shuja Tirmizi
Is there any way to generate an RTMT alert as soon  as the PRI goes down in cisco voice gateway (MGCP). I have almost 20 gateways and all have multiple T1 circuits  and need to setup on all.
yahsiel2004
Level 7
Level 7
You can configure the alerts in RTMT for "Number of Registered Gateways Decreased" and set the email address of whoever should receive the alert.
Yosh
HTH Regards, Yosh
HTH Regards, Yosh
Thanks Yosh, I have Alerts setup for "Number of Registered Gateways Decreased" but my management wants to have Alert specific for all PRI's.
I wonder if I setup alert for D-Channel "DatalinkService" does it sent alert for the status of individual PRI "Down/up
That would work. Have you considered a third-party application for managing alerts?
Yosh
HTH Regards, Yosh
