SIP SRST
Flo.Matalis
Hi Experts,
I am trying to implement SIP SRST and did the configuration below:
voice register global
default mode
no allow-hash-in-dn
system message *** Phone System Down ***
max-dn 200
max-pool 50
voice register pool 1
id network 192.168.0.0 mask 255.255.0.0
preference 1
dtmf-relay rtp-nte sip-kpml
voice-class codec 1
However, phones are not registering. I am getting this on my CUBE/SIP VG.
SIP/2.0 503 Service Unavailable - registrar unavail or not enabled
Via: SIP/2.0/UDP ###.###.###.###:5060;branch=z9hG4bK32c7ea6a
From: <sip:####@###.###.###.###>;tag=c4c60372a0b18a345fdcfb3e-58a7d431
To: <sip:####@###.###.###.###>;tag=F22C70B4-1C68
Date: Tue, 02 May 2023 07:51:52 GMT
Call-ID: c4c60372-a0b1097c-3a8b2ad5-3ea6886d@###.###.###.###
Server: Cisco-SIPGateway/IOS-16.9.5
Warning: 399 ###.###.###.### "Registrar is not enabled"
CSeq: 34850 REGISTER
Content-Length: 0
I have a connection to ITSP and we are using authentication under sip-ua so I am unable to replace the registrar IP under sip-ua.
registrar ipv4:###.###.###.### expires 3600
Any configuration I missed or a workaround?
You need registration for both, so you should move the ITSP registration configuration from the sip-ua to a tenant configuration. This frees up the sip-ua to be used for SRST.
Response Signature
b.winter
As @Roger Kallberg indicated, if you have CUBE and CME/SRST co-colocated on the same router, you must use a tenant-configuration (you will find lots of older posts about that and a lot of documentation, google is your friend).
You are also missing the following command in voice-service-voip:
voice service voip
 sip
  registrar server
