SMART LIC 12.X - how to use Bundle UWL 35 License
Greetings,
I have Activated Smart licenses to Call Manager from smart account registration.
I have noticed that it is not utilizing BE6000 Starter Bundle UWL 35 license at all. Secondly I have notices it is also not utilizing Basic Messaging User (Voicemail) license. And for one another site it is not utilizing UCXN-12X-SC-PORTS.
Can you please advice me how can I make this licenses used.
Kind Regards,
2 Accepted Solutions
The BE6000 Starter Bundle UWL 35  bundle was an old promotion AFAIK its no more active. Btw are you using FLex or perpetual license ?
This was activated using the command from CLI utils BE6000Mode enable
The licenses usage reported will be based on what you have configured . if  The user has advanced voicemail access basic licenses wont be used.
Response Signature
b.winter
You need to enter the command via CUCM-CLI "utils BE6000Mode enable" and then select the appropriate Starter Bundle.
About the Unity Licenses: Do you also have connected your Unity to the Smart Account? And have you configured Voicemail-User and / or Speech Connect Ports (they are per default in every order I think, but I have never used them)? If not, no licenses are needed and no licenses will be used.
5 Replies 5
Response Signature
Dear Nithin,
Thank you for your reply.
Yes I have perpetual license. I will try this command and check.
Dear b.winter,
Yes I have already added the Unity to Smart Account.
I have one more question, do we need to have  any Server count license. If I have 2 servers, with 1 Publisher and 1 Subscriber for CUCM and CUC.
In every Cluster (CUCM cluster with CUCM and IMP / CUC Cluster) only the Pub is taking care about the licenses.
Only pub connect with SMART account.
Response Signature
b.winter
