Unified Messaging with O365 not working after v.14SU3 - RESOLVED
ISSUE RESOLVED.  NOT SURE WHAT I DID OTHER THAN THE APP PERMISSIONS
I am getting errors with Unified Messaging connecting to O365.  I have followed the v14 config guide and updated my Azure Application Permissions to Application permissions from Delegated permissions.
Any guidance would be greatly appreciated.
                     Failed accessing xxxx@xxxx.xxx on outlook.office365.com
                     A possible reason for 403: Attempting access using HTTP when HTTPS is required.
                     HTTP status=[403 Forbidden] Diagnostic=[Bad response from server, HTTP code returned: 403] Verb=[POST] url=[https://outlook.office365.com/EWS/Exchange.ASMX] request...
I had this issue with the customer, and they ended up having to regenerate the client secret. I don't know if this is related to the same problem with LDAP integrations where the password is long. For those I had to re-enter the password for both the LDAP directory and LDAP authentication.
Saima Harris
Hi Jeffrey,
I am getting the same error and my Unified messaging is also not working.
Can you please let me know how did you resolve it ?
piyush aghera
Hi.. what permissions did you change / what permissions do you have on Azure app? I have same problem.
