Unity 8.6.2 Disk size for MCS 7845I3 sever
Hasrat Raja
under supported platform requirement for  Hard Disk it is listed as "Four 300-GB SAS 2.5-in. hot-swap hard disks; 2  RAID 1s"  for Platform 7845I3.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/supported_platforms/8xcucspl.html
Show hardware is showing as follows on my server:
PD Type: SAS
Raw Size: 279.396 GB [0x22ecb25c Sectors]
Non Coerced Size: 278.896 GB [0x22dcb25c Sectors]
Coerced Size: 278.464 GB [0x22cee000 Sectors]
is it correct size for upgrade ?
thanks
It looks like you have 4 300GB drives which meets the requirements.
This looks to be speced IBM 7845I3 which is fully supported, so you are good to go.
HTH,
Chris
Chris Deren
What version are you running now?
If appliance based can you post the full "show hardware" from CLI?
Chris
Hi Chris,
Please see show version & show hardware
thanks
admin:show version active
Active Master Version: 8.0.3.23031-1
Active Version Installed Software Options:
No Installed Software Options Found.
admin:
admin:
admin:show hardware
HW Platform       : 7845I3
Processors        : 2
Type              : Intel(R) Xeon(R) CPU           E5540  @ 2.53GHz
CPU Speed         : 2530
Memory            : 8192 MBytes
Object ID         : 1.3.6.1.4.1.9.1.587
OS Version        : UCOS 4.0.0.0-45
Serial Number     : KQ2598V
RAID Version      :
Raid firmware version: 11.0.1-0022
BIOS Information  :
IBMCorp. -[D6E131CUS-1.05]- 11/25/2009
RAID Details      :
                    Versions
Product Name    : IBM ServeRAID-MR10i SAS/SATA Controller
Serial No       : P472881910
FW Package Build: 11.0.1-0022
                Settings
Current Time                     : 14:1:30 10/8, 2012
Predictive Fail Poll Interval    : 300sec
Interrupt Throttle Active Count  : 16
Interrupt Throttle Completion    : 50us
Rebuild Rate                     : 30%
PR Rate                          : 30%
Resynch Rate                     : 30%
Check Consistency Rate           : 30%
Reconstruction Rate              : 30%
Cache Flush Interval             : 4s
Max Drives to Spinup at One Time : 2
Delay Among Spinup Groups        : 12s
Physical Drive Coercion Mode     : 1GB
Cluster Mode                     : Disabled
Alarm                            : Enabled
Auto Rebuild                     : Enabled
Battery Warning                  : Enabled
Ecc Bucket Size                  : 15
Ecc Bucket Leak Rate             : 1440 Minutes
Restore HotSpare on Insertion    : Disabled
Expose Enclosure Devices         : Enabled
Maintain PD Fail History         : Disabled
Host Request Reordering          : Enabled
Auto Detect BackPlane Enabled    : SGPIO/i2c SEP
Load Balance Mode                : Auto
Use FDE Only                     : No
Security Key Assigned            : No
Security Key Failed              : No
Security Key Not Backedup        : No
Any Offline VD Cache Preserved   : No
                Device Present
Virtual Drives    : 2
  Degraded        : 0
  Offline         : 0
Physical Devices  : 5
  Disks           : 4
  Critical Disks  : 0
  Failed Disks    : 0
Battery Back Up Information:
BBU status for Adapter: 0
BatteryType: iBBU
Voltage: 4020 mV
Current: 0 mA
Temperature: 34 C
BBU Firmware Status:
  Charging Status              : None
  Voltage                      : OK
  Temperature                  : OK
  Learn Cycle Requested        : No
  Learn Cycle Active           : No
  Learn Cycle Status           : OK
  Learn Cycle Timeout          : No
  I2c Errors Detected          : No
  Battery Pack Missing         : No
  Battery Replacement required : No
  Remaining Capacity Low       : No
  Periodic Learn Required      : No
Battery state:
GasGuageStatus:
  Fully Discharged        : No
  Fully Charged           : Yes
  Discharging             : Yes
  Initialized             : Yes
  Remaining Time Alarm    : No
  Remaining Capacity Alarm: No
  Discharge Terminated    : No
  Over Temperature        : No
  Charging Terminated     : No
  Over Charged            : No
Relative State of Charge: 100 %
Charger System State: 49168
Charger System Ctrl: 0
Charging current: 0 mA
Absolute state of charge: 61 %
Max Error: 2 %
Exit Code: 0x00
Logical Drives Information:
Virtual Disk: 0 (Target Id: 0)
Name:
RAID Level: Primary-1, Secondary-0, RAID Level Qualifier-0
State: Optimal
Stripe Size: 128 KB
Number Of Drives:2
Span Depth:1
Default Cache Policy: WriteBack, ReadAheadNone, Direct, No Write Cache if Bad BBU
Current Cache Policy: WriteBack, ReadAheadNone, Direct, No Write Cache if Bad BBU
Access Policy: Read/Write
Disk Cache Policy: Disabled
Encryption Type: None
Virtual Disk: 1 (Target Id: 1)
Name:
State: Optimal
Stripe Size: 128 KB
Number Of Drives:2
Span Depth:1
Physical Disks Information:
Slot Number: 0
Device Id: 0
Sequence Number: 2
Media Error Count: 0
Other Error Count: 0
Predictive Failure Count: 0
Last Predictive Failure Event Seq Number: 0
PD Type: SAS
Firmware state: Online
SAS Address(0): 0x5000cca00aa71375
SAS Address(1): 0x0
Connected Port Number: 0(path0)
Inquiry Data: IBM-ESXSCBRCA300C3ETS0 NC370PDXYWGBECCXSA370
FDE Capable: Not Capable
FDE Enable: Disable
Secured: Unsecured
Locked: Unlocked
Foreign State: None
Device Speed: Unknown
Link Speed: 3.0Gb/s
Media Type: Hard Disk Device
Slot Number: 1
Device Id: 1
Sequence Number: 2
PD Type: SAS
SAS Address(0): 0x5000cca00aa98a71
SAS Address(1): 0x0
Connected Port Number: 1(path0)
Inquiry Data: IBM-ESXSCBRCA300C3ETS0 NC370PDY07H1ECCXSA370
FDE Enable: Disable
Secured: Unsecured
Locked: Unlocked
Foreign State: None
Link Speed: 3.0Gb/s
Slot Number: 2
Device Id: 2
Sequence Number: 2
PD Type: SAS
SAS Address(0): 0x5000cca00aa97b4d
SAS Address(1): 0x0
Connected Port Number: 2(path0)
Inquiry Data: IBM-ESXSCBRCA300C3ETS0 NC370PDY06GTECCXSA370
FDE Enable: Disable
Secured: Unsecured
Locked: Unlocked
Foreign State: None
Link Speed: 3.0Gb/s
Slot Number: 3
Device Id: 3
Sequence Number: 2
PD Type: SAS
SAS Address(0): 0x5000cca00aacf7cd
SAS Address(1): 0x0
Connected Port Number: 3(path0)
Inquiry Data: IBM-ESXSCBRCA300C3ETS0 NC370PDY23XBECCXSA370
FDE Enable: Disable
Secured: Unsecured
Locked: Unlocked
Foreign State: None
Link Speed: 3.0Gb/s
admin:
HTH,
Chris
