Unity connection 10.5 OVA file for 500 users
Unity Connection 10.5 for 500 user we need ova files for ESXi version 6, in the URL i am able to find OVA for 500 user:
https://software.cisco.com/download/release.html?mdfid=283062758&release=OVA-10.5&softwareid=282074348&sortparam=
Please advice OVA file download link for ESXi 6.0, Unity Connection 10.5 for 500 user.
Deepak Rawat
There is no OVA for 500 users. Its either 100 or 1000 nothing in between, check below:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/supported_platforms/10xcucspl.html
You can use "Cisco Unity Connection 10.5(1) Virtual Server Template (OVA) for ESXi5.1 and higher" to deploy on ESXi 6.0 and choose 1000 users.
Deepak
- Please remember to Rate Helpful Posts and Mark as Answered when applicable -
Rob Huffman
Hi there,
I just wanted to add a note to the great tips from my friend Deepak (+5).
I think you may have been looking at the OVA for SRSV (Cisco Unity Connection Survivable Remote Site Voicemail) when you see the reference for 500 users;
Cisco Unity Connection SRSV 10.5(2) Virtual Server Template (OVA)  Login & Valid Contract Required
CUCSRSV_10.5.2_500_user_vmv8_v1.0.ova
From;
http://www.cisco.com/web/software/282074348/118836/CUCSRSV_10.5.2_500_user_vmv8_v10ovaREADME.txt
Cheers!
Rob
