Unity Connection 8.5(1)ES34 Prompt Delays on Sub.
I am noticing a 4 to 6 sec delay between prompts when calls are handled on the Subscriber server that is in a different data center as the Pub. Seems when the Connection sub retrives message counts or when a user presses * to go back to the previous menu the delays happen.
Below is a Port Status Log showing a 4 sec Delay from when I logged into my mailbox and the system played the SayHello_WithShortCut prompt.
My round trip time between the two data centers is 28ms.
Port Status Log
03:41:12, New Call, CalledId=6666,  RedirectingId=,  Origin=16,  Reason=1, CallGuid=08A949A532234D47AA0DA070846E83F5,  CallerName=2003406,  LastRedirectingId=,
LastRedirectingReason=1024, PortDisplayName=CUCM-Cluster1-1-001,[Origin=Invalid],[Reason=Invalid]
03:41:12, AttemptSignIn
03:41:12, State - AttemptSignIn.cde!Dummy
03:41:12, Event is [NULL]
03:41:12, SubSignIn
03:41:12, Subscriber Sign-In
03:41:12, State - SubSignIn.cde!AnswerPhone
03:41:12, Event is [TrueEvent]
03:41:12, State - SubSignIn.cde!AuthenticateUser
03:41:12, -->SubAuthenticate
03:41:12,         State - SubAuthenticate.cde!TryCounter
03:41:12,         State - SubAuthenticate.cde!GatherID
03:41:12,         Event is [FalseEvent]
03:41:12,         State - SubAuthenticate.cde!LoadSubscriberMinimalData
03:41:12,         State - SubAuthenticate.cde!GatherPIN
03:41:12,         -->SubAuthenticatePW
03:41:12,                 State - SubAuthenticatePW.cde!ValidatePwd
03:41:17,                 Subscriber sign-in successful. Alias - 2003406. Extension - 2003406. Caller Id - 2003406.
03:41:18,                 Event is [TrueEvent]
03:41:18,                 State - SubAuthenticatePW.cde!ReturnAuthenticated
03:41:18,                 Event is [Authenticated]
03:41:18,         <--SubAuthenticatePW
03:41:18,         State - SubAuthenticate.cde!ReturnAuthenticated
03:41:18, State - SubSignIn.cde!RunSignInUtil
03:41:18, -->SubSignInUtil
03:41:18,         State - SubSignInUtil.cde!CheckAccountLocked
03:41:18,         Event is [FalseEvent]
03:41:18,         State - SubSignInUtil.cde!CheckExpiredAndNew
03:41:18,         Event is [NULL]
03:41:18,         State - SubSignInUtil.cde!CheckForExpirationWarning
03:41:18, <--SubSignInUtil
03:41:18, State - SubSignIn.cde!RunSignInUtil_default
03:41:18, State - SubSignIn.cde!RunNextConv
03:41:18, -->SubMenu_Alternate_Custom
03:41:18,         Subscriber Mailbox (Anthony Lotito)
03:41:18,         State - SubMenu.cde!MapTemplate
03:41:18,         State - SubMenu_Alternate_Custom.cde!SetSubConversations
03:41:18,         State - SubMenu.cde!RunSubMessageBookmark
03:41:18,         -->SubMsgBookmark
03:41:18,                 State - SubMsgBookmark.cde!CheckForMsgBookmark
03:41:18,         <--SubMsgBookmark
03:41:18,         State - SubMenu.cde!RunAddAlternateExtensions
03:41:18,         -->AddAlternateExtensions
03:41:18,                 State -
AddAlternateExtensions.cde!CheckAlternateExtensionAddEnabled
03:41:18,         <--AddAlternateExtensions
03:41:18,         State - SubMenu.cde!CheckAlternateGreeting
03:41:18,         State - SubMenu.cde!CheckForSignInOverGreeting
03:41:18,         State - SubMenu.cde!RunMsgCount
03:41:18,         -->SubMsgCount_Alternate_Custom
03:41:18,                 State - SubMsgCount.cde!CountMailboxMessages
03:41:22,                 Event is [NULL]
03:41:22,                 State - SubMsgCount.cde!GetMailboxStatus
03:41:22,                 Event is [YesEvent]
03:41:22,                 State - SubMsgCount.cde!SayHello_WithShortCut
03:41:24,                 Event is [NULL]
03:41:25,                 State - SubMsgCount.cde!RunCheckBroadcastMsg_WithShortCut
03:41:25,                 -->SubBroadcastMessage
03:41:25,                         State - SubBroadcastMessage.cde!CheckForBroadcastMessage
03:41:25,                         Event is [NULL]
03:41:25,                 <--SubBroadcastMessage
03:41:25,                 State - SubMsgCount.cde!AnnounceMsgCount
03:41:28,                 Event is [HangupEvent]
03:41:28,         <--SubMsgCount_Alternate_Custom
03:41:28, <--SubMenu_Alternate_Custom
03:41:28, Idle
Any ideas as to why the delay? I don't experience any delay when the Pub is taking calls.
5 Replies 5
Brad Magnani
Hi Anthony,
It sounds similar to the behavior noted in http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCth21949&from=summary
Try making the subcriber "Primary" status in the cluster (fail it over) and then see if the delay then occurs when calls are taken by the publisher.  Regardless, you'll probably want to get a TAC case open to take a look.  This isn't an issue with ping times, it's more likely an Informix database delay you're seeing.
Hope that helps,
Brad
Brad,
Durning the installation there was a DNS error and I ignored it at the time (shame on me). I then went into the CLI and added back the DNS servers once the install completed.
My TAC case is 617305837.
I made the Subscriber the Primary in the Cluster and the delay is no longer there.
I am hoping this can be corrected by by modifying the /etc/nsswitch.conf file as you indicated in the BUG ID.
Any chance of you picking up this SR?
08:59:18, New Call, CalledId=11181,  RedirectingId=,  Origin=16,  Reason=1,  CallGuid=99D0AA71387C4FA3BE68B428A7C9EBFB,  CallerName=Anthony Lotito,  LastRedirectingId=,  LastRedirectingReason=1024,  PortDisplayName=CUCM-Cluster1-1-001,[Origin=Invalid],[Reason=Invalid]
08:59:18, AttemptSignIn
08:59:18, State - AttemptSignIn.cde!Dummy
08:59:18, Event is [NULL]
08:59:18, SubSignIn
08:59:18, Subscriber Sign-In
08:59:18, State - SubSignIn.cde!AnswerPhone
08:59:18, Event is [TrueEvent]
08:59:18, State - SubSignIn.cde!AuthenticateUser
08:59:18, -->SubAuthenticate
08:59:18,         State - SubAuthenticate.cde!TryCounter
08:59:18,         State - SubAuthenticate.cde!GatherID
08:59:18,         Event is [FalseEvent]
08:59:18,         State - SubAuthenticate.cde!LoadSubscriberMinimalData
08:59:18,         State - SubAuthenticate.cde!GatherPIN
08:59:18,         -->SubAuthenticatePW
08:59:18,                 State - SubAuthenticatePW.cde!ValidatePwd
08:59:23,                 Subscriber sign-in successful. Alias - 2003406. Extension - 2003406. Caller Id - 2003406.
08:59:23,                 Event is [TrueEvent]
08:59:23,                 State - SubAuthenticatePW.cde!ReturnAuthenticated
08:59:23,                 Event is [Authenticated]
08:59:23,         <--SubAuthenticatePW
08:59:23,         State - SubAuthenticate.cde!ReturnAuthenticated
08:59:23, State - SubSignIn.cde!RunSignInUtil
08:59:23, -->SubSignInUtil
08:59:23,         State - SubSignInUtil.cde!CheckAccountLocked
08:59:23,         Event is [FalseEvent]
08:59:23,         State - SubSignInUtil.cde!CheckExpiredAndNew
08:59:23,         Event is [NULL]
08:59:23,         State - SubSignInUtil.cde!CheckForExpirationWarning
08:59:23, <--SubSignInUtil
08:59:23, State - SubSignIn.cde!RunSignInUtil_default
08:59:23, State - SubSignIn.cde!RunNextConv
08:59:23, -->SubMenu_Alternate_Custom
08:59:23,         Subscriber Mailbox (Anthony Lotito)
08:59:23,         State - SubMenu.cde!MapTemplate
08:59:23,         State - SubMenu_Alternate_Custom.cde!SetSubConversations
08:59:23,         State - SubMenu.cde!RunSubMessageBookmark
08:59:23,         -->SubMsgBookmark
08:59:23,                 State - SubMsgBookmark.cde!CheckForMsgBookmark
08:59:23,         <--SubMsgBookmark
08:59:23,         State - SubMenu.cde!RunAddAlternateExtensions
08:59:23,         -->AddAlternateExtensions
08:59:23,                 State - AddAlternateExtensions.cde!CheckAlternateExtensionAddEnabled
08:59:23,         <--AddAlternateExtensions
08:59:23,         State - SubMenu.cde!CheckAlternateGreeting
08:59:23,         State - SubMenu.cde!CheckForSignInOverGreeting
08:59:23,         State - SubMenu.cde!RunMsgCount
08:59:23,         -->SubMsgCount_Alternate_Custom
08:59:23,                 State - SubMsgCount.cde!CountMailboxMessages
08:59:23,                 State - SubMsgCount.cde!GetMailboxStatus
08:59:23,                 Event is [YesEvent]
08:59:23,                 State - SubMsgCount.cde!SayHello_WithShortCut
08:59:25,                 Event is [NULL]
08:59:26,                 State - SubMsgCount.cde!RunCheckBroadcastMsg_WithShortCut
08:59:26,                 -->SubBroadcastMessage
08:59:26,                         State - SubBroadcastMessage.cde!CheckForBroadcastMessage
08:59:26,                         Event is [NULL]
08:59:26,                 <--SubBroadcastMessage
08:59:26,                 State - SubMsgCount.cde!AnnounceMsgCount
08:59:29,                 Event is [TimeoutEvent]
08:59:29,         <--SubMsgCount_Alternate_Custom
08:59:29,         State - SubMenu.cde!CheckMailStoreMounted
08:59:29,         Event is [FalseEvent]
08:59:29,         State - SubMenu.cde!CheckJumpToNewMessages
08:59:29,         State - SubMenu.cde!AnnounceMenu
08:59:32,         Event is [TT3Event]
08:59:32,         State - SubMenu.cde!GetMailStoreInfo
08:59:32,         Event is [UMSS_EVENT]
08:59:32,         State - SubMenu.cde!CheckDelItemMenu
08:59:32,         Event is [TrueEvent]
08:59:32,         State - SubMenu.cde!OldMessageMenu
08:59:33,         Event is [TT1Event]
08:59:34,         State - SubMenu.cde!RunOldMsgStack
08:59:34,         -->SubOldMsgStack
08:59:34,                 State - SubOldMsgStack.cde!SetFolderInProps
08:59:34,                 Event is [NULL]
08:59:34,                 State - SubOldMsgStack.cde!AnnounceMsgs
08:59:35,                 Event is [NULL]
08:59:35,                 State - SubOldMsgStack.cde!CheckTotalMsgCount
08:59:35,                 State - SubNewMsgStack.cde!CheckOfferMsgTypeMenu
08:59:35,                 Event is [FalseEvent]
08:59:35,                 State - SubNewMsgStack.cde!PlayMsgStack
08:59:35,                 -->SubMsgPlay_Alternate_Custom
08:59:35,                         State - SubMsgPlay_Custom.cde!MapTemplate
08:59:35,                         State - SubMsgPlay.cde!MsgRoot
08:59:35,                         State - SubMsgPlay.cde!ValidMsgStreams
08:59:35,                         State - SubMsgPlay.cde!MessageHeaderDispatchCheck
08:59:37,                         Event is [TimeoutEvent]
08:59:37,                         State - SubMsgPlay.cde!MessageBody
08:59:38,                         Event is [HangupEvent]
08:59:38,                         State - SubMsgPlay.cde!SetExitProperties_Hangup
08:59:38,                         Event is [NULL]
08:59:38,                         State - SubMsgPlay.cde!MessageExit_CheckMarkNew
08:59:38,                         Event is [FalseEvent]
08:59:38,                         State - SubMsgPlay.cde!MessageExit_CheckMarkRead
08:59:38,                         Event is [TrueEvent]
08:59:39,                         State - SubMsgPlay.cde!MessageExit_MarkRead
08:59:39,                         Event is [TrueEvent]
08:59:39,                         State - SubMsgPlay.cde!MessageExit_CheckToggleUrgency
08:59:39,                         Event is [FalseEvent]
08:59:39,                         State - SubMsgPlay.cde!MessageExit_CheckUndelete
08:59:39,                         State - SubMsgPlay.cde!MessageExit_RouteToAction
08:59:39,                         Event is [ExitHangup]
08:59:39,                         State - SubMsgPlay.cde!PushHangup
08:59:39,                         Event is [HangupEvent]
08:59:39,                 <--SubMsgPlay_Alternate_Custom
08:59:39,         <--SubOldMsgStack
08:59:39, <--SubMenu_Alternate_Custom
08:59:39, Idle
Hi Anthony,  We are facing the exact same symptom with 4 to 6 sec delays with prompt being played as you have described for my customer on CUC 8.5(1) Pub and Sub over WAN between datacentre on UCS.  Did the workaround for that bug rectify your issue? please advise the outcome.  Thank you, Yavuz
G'day Yavuz!
I believe the issue ended up being CSCtn78617.   Log a case with the TAC if you need an 8.6(2) ES build ( the latest of which include the fix for CSCtn78617).
Kind regards,
Craig
Will do Craig. Thank you for your support as always mate.
Your definitely the go to person for UC!!
Thanks again.
Cheers!
Yavuz
Sent from my iPhone
