Unity Connection Remote User Deletion Replication
ybpants
Level 5
Level 5
I am running 2 Unity Connection Clusters both running version 8.5.1ES47.12900-47 with an Intrasite link between them.
I have a user that has moved physical location and I now want to move his voicemail account from CUC Cluster A to CUC Cluster B.  His voicemail account was deleted from cluster A by our service desk and when I search cluster A I do not see the account listed.
When I search for the user on cluster B, the account is present and shows it as a remote user on Cluster A.
My question is, how long does it usualy take for this replication to happen and is there a way I can get a more detailed progress report?  I see the Intrasite links push and pull task both as in progress but this has been this way for a few hours now and we have not had any other changes that will need to replicate.
I uderstand that "how long" questions are very hard to answer but "in progress" does not really give any indication of what is happening or stop users complaing to me that a voicemail account does not exist.
Thanks in advance.
Rob Huffman
Hi there,
You may be hitting one of these bugs;
CSCts44047 - DN: Replicator unable to sync delete user request to remote nodes
Description
Symptom:
A remote user didn't get removed
Conditions:
Create a user on home location
Let it replicate to remote node
Stop CuReplicator
Delete the user
The replicator remained stop for more than 24 hours.
In the 24 hours, the sysagent task "run cuc sysagent task Data.CheckDynDbTables" got executed.
Start the replicator
Workaround:
none
Rate this bug description
(Select Rating)
Current description rating:
(0)
Details
1st Found-in:                          (1)
8.5(1)
Status:
Fixed
Last Modified:
Dec 13,2011
Fixed-in:                          (12)
9.0(0.96000.76), 9.0(0.96000.12), 9.0(0.28)
8.6(2.21001.1), 8.6(2)ES5, 8.6(1.21015.1)
8.6(1)ES11, 8.5(1.13900.5), 8.5(1.13039.1)
8.5(1)ES65, 8.0(3.23041.1), 8.0(3)ES39
More
Product:
Cisco Unity Connection
Platform:
Dependent
Severity:
3 - moderate
Customer Reported:                          (2)
Related Bugs
CSCts46653 : DN: Object deletions are not being tracked in tbl_ObjectChange
Symptom:
An object is deleted from its home location, but it is not deleted from any of the other locations in the network.
Conditions:
Intrasite Digital Network
Deleting a replicated object on its home location
Workaround:
None
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
Rob Huffman
Hi there,
Description
Symptom:
Conditions:
Stop CuReplicator
Delete the user
Workaround:
none
(Select Rating)
(0)
Details
1st Found-in:                          (1)
8.5(1)
Status:
Fixed
Last Modified:
Dec 13,2011
Fixed-in:                          (12)
More
Product:
Platform:
Dependent
Severity:
3 - moderate
Related Bugs
Symptom:
Conditions:
Workaround:
None
Cheers!
Rob
ybpants
Level 5
Level 5
Thanks Rob...looks like another CUC version upgrade this weekend then
