UnityConnection versioning
apu
Can someone please point me towards something that explains what UnityConnection version supersedes what version?
In this case, the client has 8.5.1ES69.14044-69 installed. They need to install some software to integrate with UnityConnection that requires a minimum of 8.5.1ES78. But, that is not one of the options to download from Cisco. There, the options are 8.5(1)SU6 and earlier SUx versions.
Where does the ES branch fit in with the SU branch? Would Software Update 6 include the fixes in Engineering Special 78?
Thanks in advance!
Rob Huffman
Hi there,
Yes this build would include the fixes from ES78 as shown in the notes from the readme below;
Version and Description
Cisco Unity Connection 8.5(1) SU 6 is a cumulative update that incorporates all of the fixes and changes
to Unity Connection version 8.5(1)—including the operating system and components shared by Unity
Connection and Cisco Unified CM. It also incorporates additional changes that are specific to this
service update, including Unity Connection Engineering Special 92.
http://www.cisco.com/web/software/282074295/106034/851su6cucrm.pdf
Cheers!
Rob
Rob Huffman
Hi there,
Cheers!
Rob
[+5] to Rob.
ES are the engineering special versions which are published by TAC for special defects and any updates when u open up the case.They are not available for downloading on Cisco site through CCOid.
regds,
aman
Rob, Aman, Thank you.
FWIW, installing 8.5(1) SU 6 results in a working install that reports itself as being version 8.5.1ES125.16900-125. No TAC case, etc. So the "Engineering Special" vs. "Service Update" nomenclature is misleading at best.
I guess Cisco knows this too, given this passage from the README:
Do not refer to version numbers in any of the administration user interfaces because those versions apply to the interfaces themselves, not to the version installed on the active partition.
