Upgrade CUCM 10 to 11.X , No valid upgrade options were found
M Rinaldy Aulia
Hi All,
Need your advice, I have a project to upgrade CUCM 10.5 to 11.X
I already have the image from Cisco Product Upgrade Tool
Filename : UCSInstall_UCOS_11.5.1.13902-2.sgn.iso
But the issue when I try to upgrade it, it said "No valid upgrade options were found"
Troubleshoot steps already taken :
1. Make sure the FTP / SFTP works
2. Make sure which CUCM version I had (Unrestricted or Restricted), I already try both version
3. rename file from UCSInstall_UCOS_11.5.1.13902-2.sgn.iso to UCSInstall_UCOS_11.5.1.13902-2.sgn
Need your advice for my issue,
Rinaldy
3 Accepted Solutions
You have to select the path SFTP.
Check from CLI method,
SSH to CUCM and login with OS username and password.
Run Below command
Utils system upgrade initiate
and fill the details
If this works fine mark my post..
The two fatal errors you get is something that you should look into. It’s not normal to get that. What software do you use for the SFTP/FTP server? The rename of the file to remove .iso, why did you do this? The upgrade file has to end with .iso, otherwise it will not be used by the system.
Can you share show status and show version active?
Response Signature
I think if you look through the upgrade log file it will show what it found in the specified directory.  That will tell you whether there's something wrong with the SFTP settings, or whether it has found but doesn't like the upgrade.  Sometimes, depending on your SFTP server you have to put the path in some special form like "./" rather than just "/".
Test with command line SFTP client if you have one.
6 Replies 6
Run Below command
Thank you, I already try on CLI but it's still said "no valid options"
I've double check and make sure my SFTP was working
Any advice?
Response Signature
Hi All,
Thank you for your suggestion.
Somehow it's work when I move the file to another directory with only contains that file.
Best Regards,
Rinaldy
Hi All,
Me too faced same issue since file corrupted, got resolved by using new file.
Thanks and Regards
Sajid Pasha Muhammad
