VG 450 Not building dial peers Tftp download failed
Dino Carota
Vg 450  not building Dial Peers
No configurations downloaded
Current state: Downloading XML file
Configuration Download statistics:
Download Attempted : 126
Download Successful : 0
Download Failed : 0
TFTP Download Failed : 47187
Configuration Attempted : 0
Configuration Successful : 0
Configuration Failed(Parsing): 0
Configuration Failed(config) : 0
Last config download command:
Do you have "ccm-mananger config" and "ccm-manager config server x.x.x.x y.y.y.y" options set? Is this MGCP or SCCP? Are you sure the hostname in CUCM matches the host name of the gateway? If you have an "ip domain name" set in the gateway config, your gateway in CUCM needs to be the FQDN of the gateway. Something like "SiteA-VG450B.mydomain.com".
As @Elliot Dierksen  requested Could you share more details about the type of integration. And if possible share your config.
Response Signature
