em 02-09-2022 06:55 AM
Hello all,
I hope you are doing well,
I have a cucm 11.5 integrated with Im&Presence all work fine but i have a user account with jabber and voicemail , the problem that i have when i connect that user in cisco jabber desktop i can't use voice mail we can show this in screnshot , username and password are not correct.
Could you help me please !
Best regards
Solucionado! Ir para a Solução.
em 02-16-2022 05:13 AM
Finally the problem is resolved , i change the order on message vocal profile primary for CUCM publisher and secondary for CUC subscriber , because i had a problem of replication in CUC.
Thank you for your help.
Best regards
02-09-2022 07:06 AM - editado 02-09-2022 07:07 AM
Can you explain a little bit more your setup?
Do you use LDAP authentication in CUCM and / or Unity?
Or do you use local end users?
How is your service-profile configured in CUCM? (--> user mgmt --> user settings --> service profile --> credential source for voicemail service)
As the screenshot explains, the username/password that jabber is using to login into voicemail is not correct.
So, in Unity, either there is no user, or the user has a different (local) password set.
em 02-09-2022 07:44 AM
Thank you for your reply ,
-Do you use LDAP authentication in CUCM and / or Unity? both LDAP authentication in CUCM and LDAP authentication in unity.
-How is your service-profile configured in CUCM? is configured correctly because it's work with another user.
Best regards
em 02-09-2022 08:05 AM
If both systems have LDAP authentication configured and assuming, the user was synced into CUCM and Unity, then there cannot be username/password mismatch.
Only the user is a local user in Unity. Then you have to set the password manually for that user.
Maybe the user is locked in unity for multiple failed logins or something.
Has the user been synced with LDAP? Or is it a local end user in both or one of the systems?
What does Jabber PRT say?
02-10-2022 12:07 AM - editado 02-10-2022 12:10 AM
Has the user been synced with LDAP? Or is it a local end user in both or one of the systems? yes , this user is synced from LDAP for both cucm an cuc.
Normaley we put the password not PIN ?
em 02-10-2022 12:20 AM
So:
If in CUCM and CUC the users where synced via LDAP, and also LDAP authentication is configured, you are able to login to Jabber (CUCM) but not in CUC? That doesn't make any sense...
Is the user able to login to CUC voicemail page https://<CUC-IP>/inbox?
Have you already checked the PRT?
Can you make a screenshot of the user in CUCM and CUC?
Also send a screenshot of the service profile in CUCM.
Also please check the settings in Jabber --> Settings --> Accounts --> Voicemail --> Server Settings
What do you mean with "Normaley we put the password not PIN ?"
em 02-10-2022 12:54 AM
I loging jabber to IM & Presence not CUC.
All ather users work fine with VM in jabber just one user .
What do you mean with "Normaley we put the password not PIN ?" i mean the password with LDAP not pin with numbers.
02-10-2022 01:10 AM - editado 02-10-2022 01:14 AM
I loging jabber to IM & Presence not CUC. --> And still, Jabber is automatically trying to login to CUC, since you have set up the voicemail integration in Jabber...
Have you tried to login with that user in the /inbox site as instructed? If the user is not able to login to this site, he won't be able to login via voicemail service in Jabber either!!
What about the other questions I asked?
I don't know, what you want me to say with the PIN stuff. I didn't say anything about a PIN before...
People here are trying to help on a voluntary basis and spending their own time.
The least that those people expect, is that the questions asked and instructions given are answered. If not, it's just time wasting...
02-10-2022 05:27 AM - editado 02-10-2022 07:10 AM
No one mentioned PIN, why did you bring this up? Please follow the suggestions given. They where suggested for a reason.
em 02-10-2022 05:42 AM
Just i would like to know normally we put password in voicemail with cisco jabber or PIN .
Best regards
em 02-10-2022 05:59 AM
In the voicemail service in Jabber, you need to put the user's password.
em 02-10-2022 06:12 AM
If I understand the thread correctly: a working user and a non-working user both have the same UC Service Profile in CUCM; working user and the non-working user are both LDAP-integrated/authenticated in both CUCM and CUC; and both users are able to log into Jabber itself successfully. Are these correct?
Another thing to check is the Class of Service in Unity Connection. A user must be enabled for IMAP in the Class of Service in Unity Connection for the voicemail tab in Jabber to work. Please check that.
Maren
em 02-10-2022 06:54 AM
Hey @Maren Mahoney,
for the Jabber integration, you don't need IMAP in the Class of Service activated.
The things, that need to be activated are:
Check out this document:
em 02-11-2022 05:26 AM
Hi , @ Maren Mahoney i activated this things but stil no change , Voice mail tab not displaying in my cisco jabber .
Best regards
em 02-10-2022 08:56 AM
Hello thank you for your reply,
Yes its correct.
I checked the Class of service in unity connection : for allow users to access VM using an IMAP Client
Best regards
Descubra e salve suas ideias favoritas. Volte para ver respostas de especialistas, passo a passo, tópicos recentes e muito mais.
Novo por aqui? Comece com estas dicas. Como usar a Comunidade Guia do novo membro
