1000v / VSG - Packets not being sent to policy engine
Paul Marks
Hi All,
I've got my 1000v, VNMC and VSG installed and all registered with one another. I've created a simply policy in VNMC for testing of allow all. However, as soon as I assign it to my port-profile all traffic flow stops, yet nothing is ever hitting the policy engine.
This is my port profile:
port-profile type vethernet Test-VM
  vmware port-group
  switchport mode access
  switchport access vlan 10
  org root/TestTenant
  vservice node VSG profile MyProfile
  no shutdown
  state enabled
And this is the output of "show vservice brief":
N1000v# show vservice brief
License Information
Type      In-Use-Lic-Count  UnLicensed-Mod
vsg                      2
asa                      0
Node Information
ID Name                     Type   IP-Address      Mode   State   Module
1 VSG                      vsg    10.1.20.99      v-20   Alive   3,
Path Information
Port Information
PortProfile:Test-VM
Org:root/TestTenant
Node:VSG(10.1.20.99)                          Profile(Id):MyProfile(3)
Veth Mod VM-Name                              vNIC IP-Address
1   3 2k3                                     1 10.1.10.200,
Show it appears the 1000v is happy it's received valid config for the VSG. Seems fine too, it has the rule:
firewall# show run rule
rule MyACL/PermitAll@root/TestTenant
action 10 permit
rule default/default-rule@root
action 10 permit
firewall# show run policy
Policy MyACLSet@root/TestTenant
rule MyACL/PermitAll@root/TestTenant order 201
Policy default@root
rule default/default-rule@root order 2
However... Nothing ever gets punted up for policy inspection:
firewall# show policy-engine stats
Policy Match Stats:
default@root                 :                   0
default/default-rule@root  :                   0 (Permit)
NOT_APPLICABLE             :                   0 (Drop)
MyACLSet@root/TestTenant           :                   0
MyACL/PermitAll@root/TestTenant  :                   0 (Permit)
And I just can't fathom why.... any thoughts greatly appreciated!
6 Replies 6
Paul Marks
OK, I'd forgotten my vPath config, I've added that:
vservice path vpath
node VSG profile MyProfile order 1
And the corresponding node config that was there before:
vservice node VSG type vsg
ip address 10.1.20.99
adjacency l2 vlan 20
fail-mode open
And traffic is flowing... but nothing is hitting the policy engine and nothing is denied even if I ask the rules to deny all.
Update: Traffic is flowing only thanks to the "fail open" setting in the VSG setting. That's why counters aren't going up, but I can't work out where I've gone wrong. Any thoughts?
OK, I'm confused...
If I use:
In my port-profile I can see packets on the 1000v matching:
N1000v# show vservice statistics
#VSN  VLAN: 20, IP-ADDR: 10.1.20.99
Module: 3
#VPath Packet Statistics     Ingress         Egress           Total
Total Seen                        26             29              55
Policy Redirects                  26             29              55
But no counters going up on the VSG and devices behind that port profile are unreachable.
If I switch to:
vservice path vpath
Module: 3
Total Seen                        26             29              55
With the above vpath specified, I get just counters on fail-open going up, and nothing on the VSG again, but devices are reachable.
Any thoughts?
A small update...
Looking in VNMC, it says the VM/Port-Profile is associated with the IP "10.1.20.99" which it says is a non-existent firewall. That's the managment address of the VSG in question.
I then realised when you add the VSG to VNMC it asks you to create a data address, which I did and set to "10.1.20.100". I tried changing my node settings in the 1000v to use that address instead but it then says that the VSG is down (it's up when set to 10.1.20.99)
What is that data address used for? Or am I going in the wrong direction?
skalje
Paul,
From your port-profile config :
org root/TestTenant
You have used Security Profile MyProfile. In VNMC have you created Security Profile with same name - MyProfile(name is case sensitive), within Tenant- TestTenant associated with your compute firewall. All the Policy Sets will be part of this security profile.
To check other configurations look fine, From VSM can you get the output for following commands :
Module vem 3 execute vemcmd show vsn binding
Module vem 3 execute vemcmd show vsn config
Dear Skalje,
I am having the same issue. I have a ASA managed via ASDM with VService Node configuration iusing 10.1.1.1 for its inside address and for the VSG 10.1.1.2 for the data0 interface on the VSG. However the ASA is reachable but the VSG is not. Previously I had a the vservice node IP address for the VSG in the same subnet as the Management0 address of the Nexus1000v and this worked fine, with service chaining enable and applied to a port profile.
What I am trying to understand is does the VSM and VEM need to communicate with the VSG at Layer2 or Layer3. As the ASA does not seem to need to do, as the ASA is alive with the insdie IP set to 10.1.1.1?
Here is the output you request from the previous post?
gs2-cldnexus-01# Module vem 3 execute vemcmd show vsn binding
  VSG Services Enabled  | VSG Licenses Available   2
  ASA Services Enabled  | ASA Licenses Available   2
   LTL  PATH   VSN  SWBD               IP  P-TYPE  P-ID
    50     1     3   501         10.1.1.2       1     7
    50     1     1   501         10.1.1.1       2     3
    56     1     3   501         10.1.1.2       1     7
    56     1     1   501         10.1.1.1       2     3
    66     2     2   506         10.1.2.1       2     5
    69     2     2   506         10.1.2.1       2     5
gs2-cldnexus-01#
gs2-cldnexus-01#
gs2-cldnexus-01# Module vem 3 execute vemcmd show vsn config
  VSN#  SWBD               IP                MAC  LTLs VER     VER-BITMAP
     1   501         10.1.1.1  00:50:56:ba:1a:61     2   2            1,2
     2   506         10.1.2.1  00:50:56:ba:76:8c     2   2            1,2
     3   501         10.1.1.2  00:00:00:00:00:00     2   1              1
Also from show vservice brief
gs2-cldnexus-01# show vservice brief
                                   License Information
vsg                      2
asa                      2
                                   Node Information
  1 CUST01-ASA               asa    10.1.1.1        v-501  Alive   3,
  2 CUST02-ASA               asa    10.1.2.1        v-506  Alive   3,
  3 CUST01-VSG-01            vsg    10.1.1.2        v-501  Unreach 3,
                                   Path Information
Name:CUST01-Chain                   NumOfSvc:2  Mod:3,
Node                        Order   Profile
CUST01-VSG-01                  1   CUST01-Server-Compute-Profile
CUST01-ASA                     2   Profile-CUST01-Server
                                   Port Information
PortProfile:Profile-CUST01-Server
Org:root/CUST01
Path:CUST01-Chain
Node                                          Profile(Id)
CUST01-VSG-01(10.1.1.2)                      CUST01-Server-Compute-Profile(7)
CUST01-ASA(10.1.1.1)                         Profile-CUST01-Server(3)
   3   3 cust01-vm01                             1 10.1.1.10
  10   3 cust01-router01                         3 10.1.1.254
PortProfile:Profile-CUST02-Server
Org:root/CUST02
Node:CUST02-ASA(10.1.2.1)                     Profile(Id):Profile-CUST02-Server(5)
   5   3 cust02-vm01                             1 10.1.2.10
  12   3 cust02-router01                         3 10.1.2.254
Darren Frowen
darren.frowen
Hi All,
This issue is now resolved. Although I had defined the VSG security Profiles, and assigned the VSG to the Tennat. What I had failed to perform is the Assisgn to VSG in the same Window, seen at the top right hand corner.
It does appear that there is only a requirement for L2 or L3 communication between the VEM and the VSM. As long as you have that using Layer2 address for the VSG data interface or the ASA inside interface for the VSN config is fine, as I belience that the Tunnel created for the vPath communication is between the vmk on the VEM and the Mgmt of the VSM, mac in mac or UDP at L3.
Configuration now looks great and I have service chaining working perfectly;
gs2-cldnexus-01# sh vservice brief
                                   License Information
vsg                      2
asa                      2
                                   Node Information
  1 CUST01-ASA-01            asa    10.1.1.1        v-501  Alive   3,
  2 CUST02-ASA-01            asa    10.1.2.1        v-506  Alive   3,
  3 CUST01-VSG-01            vsg    10.1.1.2        v-501  Alive   3,
  4 CUST02-VSG-01            vsg    10.1.2.2        v-506  Alive   3,
                                   Path Information
Name:CUST01-CHAIN                   NumOfSvc:2  Mod:3,
Node                        Order   Profile
CUST01-VSG-01                  1   CUST01-Server-Comp-Profile-01
CUST01-ASA-01                  2   CUST01-Server-Edge-Profile-01
Name:CUST02-CHAIN                   NumOfSvc:2  Mod:3,
Node                        Order   Profile
CUST02-VSG-01                  1   CUST02-Server-Comp-Profile-01
CUST02-ASA-01                  2   CUST02-Server-Edge-Profile-01
                                   Port Information
PortProfile:CUST02-Server-Chained-Profile-01
Org:root/CUST02
Path:CUST02-CHAIN
Node                                          Profile(Id)
CUST02-VSG-01(10.1.2.2)                      CUST02-Server-Comp-Profile-01(16)
CUST02-ASA-01(10.1.2.1)                      CUST02-Server-Edge-Profile-01(11)
   5   3 cust02-vm01                             1
PortProfile:CUST01-Server-Chained-Profile-01
Org:root/CUST01
Path:CUST01-CHAIN
Node                                          Profile(Id)
CUST01-VSG-01(10.1.1.2)                      CUST01-Server-Comp-Profile-01(12)
CUST01-ASA-01(10.1.1.1)                      CUST01-Server-Edge-Profile-01(10)
   3   3 cust01-vm01                             1
Darren Frowen
