2.0 Upgrade
peter.robertson
Has anyone completed the upgrade to 2.0?  And if so, how was your experience?
I have the firmware bundles downloaded and am preparing to run the upgrade but wanted to know if anyone has run into any issues.  I have checked and do not have any FCoE VLAN overlap.
41 Replies 41
Maybe, see my post below.
Craig
My UCS Blog http://realworlducs.com
Greetings All,
The UCS 2.0 patch 2.0(1q) has been released which addressed the two major bugs detailed above.
Release Notes:
http://www.cisco.com/en/US/docs/unified_computing/ucs/release/notes/OL_25363.html#wp232083
Software:
http://www.cisco.com/cisco/software/release.html?mdfid=283612660&flowid=22121&softwareid=283655658&release=2.0%281q%29&relind=AVAILABLE&rellifecycle=&reltype=latest
Highlights of major issues fixed:
Using the UCSM GUI, you are now able to disassociate a service profile that is currently bound to a template. (CSCts95454)
When  you assign an org to a locale from the GUI, the operation sometimes  fails due to an internal error.  This error is now corrected.  (CSCts60863)
The  PCI Device address of a VNIC will not change after an upgrade of UCS  Manager from Release 1.x to Release 2.0(1q). (CSCts96949)
When  the DHCP server is using an option 67 (RFC 2132) to report the bootfile  name to the gPXE client, gPXE will receive the boot parameters and the  boot will function normally. (CSCts86689)
BIOS
When the BIOS is upgraded on a B230-M1 blade from Release 1.x to Release 2.0, the PCI address is preserved. (CSCts86890)
A  B230-M1 blade discovered while running 1.4 BIOS release image and now  running a UCS 2.0 release BIOS image will associate and disassociate  normally. (CSCtj54470)
A  Blade with a service profile with a 22 character or longer name will  boot as expected from the local disk after upgrading the BIOS from a 1.x  release to the BIOS in the 2.0(1q) release. (CSCtt13313)
Robert
kg6itcraig
Since the code update been trying to figure out why if we select “Enable Failover” for our MetaData vNIC template (updating), or corresponding vNIC’s in service profiles traffic will not flow between upstream switch and FI’s. I can try downing a port-channel and that does not fix issue. Have tried each. Have to select an FI and not enable failover for traffic to flow. This was not the case before update.
Upstream 3750 switch config for MetaData VLAN.
interface Port-channel8
description UCS trunk to FIA
switchport trunk allowed vlan 512
switchport mode trunk
interface Port-channel9
description UCS trunk to FIB
Corresponding UCS CLI output below.
UCS02-A(nxos)# show cdp neighbors
Capability Codes: R - Router, T - Trans-Bridge, B - Source-Route-Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater,
                  V - VoIP-Phone, D - Remotely-Managed-Device,
                  s - Supports-STP-Dispute
Device-ID             Local Intrfce Hldtme Capability  Platform      Port ID
UCS02-B(SSI135004JB)  mgmt3         144    S I s     N10-S6200     mgmt3
VLP127C7000NS002(JAF1429CKER)Eth3/3        164    R S I s   N7K-C7010     Eth10/26
VLP127C7000NS002(JAF1429CKER)Eth3/4        164    R S I s   N7K-C7010     Eth10/25
SAN127C3750NS001      Eth3/5        176    S I       WS-C3750X-48  Ten3/1/1
SAN127C3750NS001      Eth3/6        176    S I       WS-C3750X-48  Ten3/1/2
UCS02-B(nxos)# show cdp neighbors
UCS02-A(SSI15120GEM)  mgmt3         166    S I s     N10-S6200     mgmt3
VLP127C7000NS002(JAF1429CKER)Eth3/3        136    R S I s   N7K-C7010     Eth10/28
VLP127C7000NS002(JAF1429CKER)Eth3/4        136    R S I s   N7K-C7010     Eth10/27
SAN127C3750NS001      Eth3/5        146    S I       WS-C3750X-48  Ten2/1/1
SAN127C3750NS001      Eth3/6        146    S I       WS-C3750X-48  Ten2/1/2
UCS02-A /eth-uplink # show pin-group MetaData expand
Ethernet Pin Group:
    Ethernet Pin Target:
        Fabric Endpoint
        A      fabric/lan/A/pc-2
        B      fabric/lan/B/pc-2
UCS02-A /eth-uplink # show interface
Member Port:
Fabric ID  Port-channel Slot  Port  Oper State    State Reason                        Lic State            Grace Period
A          1            3     3     Up                                                Unknown                            0
A          1            3     4     Up                                                Unknown                            0
A          2            3     5     Up                                                Unknown                            0
A          2            3     6     Up                                                Unknown                            0
B          1            3     3     Up                                                Unknown                            0
B          1            3     4     Up                                                Unknown                            0
B          2            3     5     Up                                                Unknown                            0
B          2            3     6     Up                                                Unknown                            0
UCS02-A# scope eth-uplink
UCS02-A /eth-uplink # scope fabric a
UCS02-A /eth-uplink/fabric # show port-channel detail
Port Channel:
    Port Channel Id: 1
    Name:
    Admin State: Enabled
    Oper State: Up
    Speed: 10 Gbps
    Speed: 10 Gbps
    State Reason:
    flow control policy: default
    Port Channel Id: 2
    Name:
    Oper State: Up
    Speed: 10 Gbps
    Speed: 10 Gbps
    State Reason:
UCS02-A /eth-uplink/fabric # show port-channel expand
Port Channel:
    Port Channel Id: 1
    Name:
    Oper State: Up
    State Reason:
    Member Port:
        Slot Id Port Id Membership Oper State State Reason  Lic State Grace Period
        3       3       Up         Up                       Unknown              0
        3       4       Up         Up                       Unknown              0
    Port Channel Id: 2
    Name:
    Oper State: Up
    State Reason:
    Member Port:
        3       5       Up         Up                       Unknown              0
        3       6       Up         Up                       Unknown              0
Port Channel:
    Port Channel Id: 1
    Name:
    Oper State: Up
    Speed: 10 Gbps
    Speed: 10 Gbps
    State Reason:
    Port Channel Id: 2
    Name:
    Oper State: Up
    Speed: 10 Gbps
    Speed: 10 Gbps
    State Reason:
Port Channel:
    Port Channel Id: 1
    Name:
    Oper State: Up
    State Reason:
    Member Port:
        3       3       Up         Up                       Unknown              0
        3       4       Up         Up                       Unknown              0
    Port Channel Id: 2
    Name:
    Oper State: Up
    State Reason:
    Member Port:
        3       5       Up         Up                       Unknown              0
        3       6       Up         Up                       Unknown              0
The VLAN for MetaData is 512
UCS02-A(nxos)# show vlan id 512
VLAN Name                             Status    Ports
512  VLAN0512                         active    Po1, Po2
Remote SPAN VLAN
Disabled
Primary  Secondary  Type             Ports
UCS02-B(nxos)# show vlan id 512
Remote SPAN VLAN
Disabled
UCS02-A(nxos)# show vlan brief
1    default                          active    Po1, Po2, Eth1/21, Eth1/22
                                                Eth1/23, Eth1/24, Eth1/25
                                                Eth1/26, Eth1/27, Eth1/28
                                                Eth1/29, Eth1/30, Eth1/31
                                                Eth1/32, Eth1/33, Eth1/34
                                                Eth1/35, Eth1/36, Eth1/37
                                                Eth1/38, Eth1/39, Eth1/40
                                                Eth3/1, Eth3/2, Eth1/1/1
                                                Eth1/1/2, Eth1/1/3, Eth1/1/4
                                                Eth1/1/5, Eth1/1/6, Eth1/1/7
                                                Eth1/1/8, Eth2/1/1, Eth2/1/2
                                                Eth2/1/3, Eth2/1/4, Eth2/1/5
                                                Eth2/1/6, Eth2/1/7, Eth2/1/8
                                                Eth3/1/1, Eth3/1/2, Eth3/1/3
                                                Eth3/1/4, Eth3/1/5, Eth3/1/6
                                                Eth3/1/7, Eth3/1/8, Eth4/1/1
                                                Eth4/1/2, Eth4/1/3, Eth4/1/4
                                                Eth4/1/5, Eth4/1/6, Eth4/1/7
                                                Eth4/1/8, Eth5/1/1, Eth5/1/2
                                                Eth5/1/3, Eth5/1/4, Eth5/1/5
                                                Eth5/1/6, Eth5/1/7, Eth5/1/8
                                                Eth6/1/1, Eth6/1/2, Eth6/1/3
                                                Eth6/1/4, Eth6/1/5, Eth6/1/6
                                                Eth6/1/7, Eth6/1/8, Eth7/1/1
                                                Eth7/1/2, Eth7/1/3, Eth7/1/4
                                                Eth7/1/5, Eth7/1/6, Eth7/1/7
                                                Eth7/1/8, Eth8/1/1, Eth8/1/2
                                                Eth8/1/3, Eth8/1/4, Eth8/1/5
                                                Eth8/1/6, Eth8/1/7, Eth8/1/8
                                                Eth9/1/1, Eth9/1/2, Eth9/1/3
                                                Eth9/1/4, Eth9/1/5, Eth9/1/6
                                                Eth9/1/7, Eth9/1/8, Eth10/1/1
                                                Eth10/1/2, Eth10/1/3, Eth10/1/4
                                                Eth10/1/5, Eth10/1/6, Eth10/1/7
                                                Eth10/1/8
2    fcoe-vsan-2                      active    veth11560, veth11568, veth11576
                                                veth11584, veth11592, veth11600
                                                veth11608, veth11616, veth11624
                                                veth11632, veth11640, veth11688
                                                veth11690, veth11706, veth11708
                                                veth11716, veth11718, veth11726
                                                veth11728, veth11736, veth11738
                                                veth11746, veth11748, veth11756
                                                veth11758, veth11766, veth11768
                                                veth11776, veth11784, veth11792
                                                veth11800, veth11808, veth11816
                                                veth11832, veth11840, veth11848
                                                veth11856, veth11864, veth11872
                                                veth11880, veth11888, veth11896
                                                veth11904, veth11912, veth11920
                                                veth11928, veth11936, veth11944
                                                veth11952, veth11960, veth11968
                                                veth11976, veth11984, veth11992
                                                veth12000, veth12008, veth12016
                                                veth12024, veth12032, veth12040
                                                veth12048, veth12056, veth12064
                                                veth12072, veth12080, veth12088
                                                veth12096, veth12104, veth12112
                                                veth12120, veth12128, veth12201
7    VLAN0007                         active    Po1, Po2
10   VLAN0010                         active    Po1, Po2
20   VLAN0020                         active    Po1, Po2
4044 SAM-vlan-management              active    Eth1/1/9, Eth2/1/9, Eth3/1/9
                                                Eth4/1/9, Eth5/1/9, Eth6/1/9
                                                Eth7/1/9, Eth8/1/9, Eth9/1/9
                                                Eth10/1/9
4047 SAM-vlan-boot                    active
4048 VLAN4048                         active    Po1, Po2
Totally do not get why this is happening.
Craig
In the end it was a config error I didn't notice until the update. Had a VLAN not global, but only one one FI. Was nothing todo with the code update.
v-crsimp
OK let's "Man Up" try this again. I am pushing to the back of the line. Will see how this goes for ya'll first.
New Reliease Patch 2.0(1q).
http://www.cisco.com/cisco/software/navigator.html?mdfid=282558030&flowid=22121
Good Luck!
Craig
2/21/2012
After taking a break to let some code updates roll, ran the 2.0(1w) code update without error. Nice and smooth like usual.
My standard order for code updates.
1)      CIMC
2)      IOM (which will wait until the FI’s update)
3)      UCSM
4)      FI X (Which ever is the current passive FI)
5)      FI X (Second FI)
Craig
Thanks for the feedback Craig (as always).
Don't forget to update the blade components (Adaptors, BIOS and Board Controllers) after the FIs are completed
Rob
Hi Lorenz,
I think from the screenshots you've attached, they only showed the VLAN ID and VSAN ID. It should not be a problem if they are the same. Could you please click on the default VSAN and check FCoE ID is also 1? Otherwise it could match the description of CSCtr74091 at
http://www.cisco.com/web/software/datacenter/ucs/UCS_2_0_Software_Advisory.htm
lorenzobexer
we have a UCS Infrastructure consisting of 2 FI (6120XP) and 2 chassis. We are currently on 1.4(3l) and want to upgrade to UCS 2.0(t).
I think we have a case of VLAN overlapping here, can someone confirm that by this screenshots:
We use B200-M2 Blades with ESXi running on them, and all VM disks + ESXi boot disks are located in the SAN.
So i wondered if it really is such a good idea to change the default VSAN and so disabling the disks of all VMs for a moment. We already had problems with Linux systems setting their filesystem to read-only after a short SAN failure.
Isn't it a better idea to just change the default Ethernet VLAN and to only risk a short network connectivity outage?
Also I'm a little worried by the experience of Craig back in September. Even after the VLAN overlapping was fixed, all of the blades crashed during the upgrade.
That's just something that can't happen to our production environment as it would take weeks to fix all the problems this would cause.
Has this issue been fixed or would it be better to go to the latest 1.4 firmware?
Thanks in advance and Regards
Yes you are stuck with the overlap issue.
Don't think you can remove/change VLAN 1. It is hardcoded I believe on Cisco.
You are stuck with changing the VSAN to two. UCSM will tell you if a change is going to reboot stuff and you can cancel. We changed for the code update and all servers were off. I don't remember what happened when we changed, sorry. Maybe try the simulator, or just call TAC. TAC has been beaten up quite a good deal over this and has the answers.
1.4m to 2.0(1w) went fine and didn't bother our Hyper-V servers. We don't do ESX. Was a very smooth update. None of the PCI Bus renumbering that caused issues first 2.0 code level appeared.
One bit of worry was blades show to be "Configuring" as each FI/IOM's reboot. But they are up.
Craig
Robert Elmes
We recently upgrade a test/demo environment from 1.3(1c) to 2.0(1w).  Normal update process followed, but when it came to the Fabrics the first one upgraded ok but the second fabric crashed and wouldn't upgrade.
Raised issue with TAC but we needed to get on with the upgrade, as we only had a short test window on this system, so in the end powered off/on the failed fabric.  This resolved the issue and the fabric upgraded.  TAC have now come back to us with information on the reason.  New bug: CSCty19988.
Robert Elmes,
Is there anything unique about your environment that caused this? What do you have attached to your FI's? Are you boot from SAN, do you use SAN (and if so what switches are attached), do you have port-channels etc? If you don't mind me asking.
We have a few more UCS's to upgrade in the next few weeks. We try to load our test UCS up with as tricky a configuration as possbile, so it will run into issues the production ones might.
But still, once in a while...
Craig
