How to clear error counters on IOM?
azabo4871
How do I clear error counters on IOM fabric ports (NI Error Counters)?
Thanks in advance.
Kind Regards,
Andy
Kirk J
Greetings.
Only a reset (hard or soft) will clear.
Kirk...
Thanks for information. We will give it a try.
BR,
Andy
Qiese Dides
I know this is a bit late but some helpful information for your records if you wanted to learn to clear the counters on the ASIC. You would run the following commands when SSH'd into the Fabric Interconnect.
connect nxos
debug hardware internal carmel clear-counters error
The reason clear counters does not work for the above command (ASIC) is because they are separate functions. The interface counters vs ASIC counters.
Hope that extra information would assist you in the future.
Qiese Dides
After "debug hardware internal carmel clear-counters error", does it make a reset of IOM ? because I have always the CRC error in GUI, in fabric ports of IOM chassis.
How can I have the CRC counter of theses fabric ports in CLI interface, because I can't find theses values in CLI mode?
Regards.
Stephane
