How to fix error [FSM:FAILED]: sam:dme:MgmtControllerUpdateSwitch (error code:F999693)
sendi-septiawan
I have Fabric Interconnect 6120, I try to update firmware from 1.4 to 2.1,
suddenly the load activated firmware stuck and error [FSM:FAILED]: sam:dme:MgmtControllerUpdateSwitch (error code:F999693),
how to fix this problem?
thanks,
sendi
Walter Dey
The manual is not very helpful here, see below; I would open a TAC case.
fsmFailMgmtControllerUpdateSwitch
Fault Code:F999693
Message
Explanation
None set.
Recommended Action
Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. Also refer to the Release Notes for Cisco UCS Manager and the Cisco UCS Troubleshooting Guide. If you cannot resolve the issue, execute the show tech-support command and contact Cisco Technical Support.
Fault Details
Severity: critical
Cause: fsm-failed
mibFaultCode: 999693
mibFaultName: fsmFailMgmtControllerUpdateSwitch
moClass: mgmt:Controller
Type: fsm
I am also getting the below error. Could you please help me to resolve this error.
Affected object           :           sys/user-ext
Description      :           [FSM:FAILED]: user configuration(FSM:sam:dme:AaaUserEpUpdateUserEp). Remote-Invocation-Error: Failed to configure AAA login block on NXOS, SAM coupler version not supported
Thanks .
Suresh
Keny Perez
Level 8
Level 8
Sendi,
As Walter said, you better open a case... doing a quick research I find mates doing a downgrade and then try an upgrade again to solve it.  Others just do the upgrade again and do a "Force" activation which is available in the Auto Install beginning with UCSM 2.1.
Just before you open the case, what is the process you used to upgrade, Manual or Auto Install?  If you did it manually, did you follow the steps to do it in the right order? failing to do it in this wait can cause this type of problems.
Let us know...
Rate ALL helpful answers.
-Kenny
Sendi,
Is fabric working fine now?
-Kenny
