03-14-2013 01:34 PM - edited 03-01-2019 10:55 AM
Hi Guys.
I want to create a RSPAN session on the 1000v, i need to copy packets from a veth local interface and send the packets into a different flat L2 vlan, is this possible because i only see that 1000v can do local span and erspan?
thanks
Solved! Go to Solution.
03-14-2013 03:54 PM
03-14-2013 01:49 PM
Christopher,
Unfortunately you are limited to just SPAN or ERSPAN.
louis
03-14-2013 02:20 PM
what so there is no way i can copy packets into another VLAN?
i thought 1000v used to support this or has that no been the case?
03-14-2013 02:37 PM
We never supported RSPAN.
You can set a vlan as source but I can't think of a way to set it as a destination.
What are you trying to do? Maybe there is another way to accomplish it.
louis
03-14-2013 03:04 PM
okay no problem thanks.
i have now configured a local span but i keep getting this error -
Src/Dst LC mismatch
monitor session 1
source interface Vethernet2 both
source interface Vethernet3 both
destination interface Vethernet1
no shut
any ideas?
thanks
03-14-2013 03:54 PM
Are your veths on the same host?
can't do a span across VEMs.
Robert
03-15-2013 07:03 AM
yes that seems to work now Robert thanks.
although i have just noticed another issues, i can no longer https to my VSM, i need to be able to do this because i am using the 1000v as an external switch provider with VMware vShield, which uses
https://10.200.7.86/n1k/services/NSM service API base.
but i cannot even get to https://
i can ping, VSM and provision port-groups to vCenter but i can no longer https to it
any ideas?
thanks
03-15-2013 07:10 AM
Can you check and see if regular http is working?
Just try http://vsm-ip-address
then check with show feature and make sure http-server is on.
louis
03-15-2013 07:10 AM
Post the output of
show http-server
If its running, then try accessing from a host on the same subnet/VLAN. Might be a firewall in the way somewhere.
Robert
03-15-2013 07:15 AM
the output is as follows,
nessa# sh http-server
http-server enabled
http protocol enabled
https protocol enabled
there is no firewall and i have tried from the same subnet but no joy
any other ideas?
03-15-2013 08:30 AM
I assume this worked at one time? Might want to try a "system switchover" to see if that kickstarts it again.
Anything in the logs (show log | last 20) after trying to reach the VSM by https?
Robert
03-15-2013 08:33 AM
Hi robert.
i have rebooted the VSM and its now working, for some reason i cannot create a secondary VSM it never actually syncs with its primary. so i left that issues for now.
going to have another as to why i cannot get these VSM in HA mode.
03-15-2013 08:36 AM
Glad http server is working now.
Will the two VSMs sync up if you put them on the same host? If not, then you have bigger issues. If they're not syncing on different hosts, it's likely an issue with AIPC (control) communication.
Robert
