Nic Teaming and Port channel
opnineopnine
Hello
I have to configure the port channel for the nic teaming I have created in the ucs 240 , this is the actual config I have but is not working
Any ideas?
thanks.
interface Port-channel2
description UCS01
switchport mode access
ip dhcp snooping trust
interface GigabitEthernet1/0/3
description UCS-01
spanning-tree portfast
channel-protocol lacp
channel-group 2 mode active
interface GigabitEthernet2/0/3
description UCS-01
Keny Perez
Level 8
Level 8
Just asking... do you really need the port-channel to be in "access" mode?  Usually the ports are configured for edge trunk so you can take advantage of virtualization and the port can come up faster while passing multiple vlans.
Did you set up a native vlan in the UCS side?  are the ports on the UCS part of the same PCIe card?
-Kenny
Keny Perez
Level 8
Level 8
-Kenny
Hello Keny
I will to do the change to edge trunk and for the ucs side, I have configured all vlans not a specific one.
thanks.
