Question on reset I/O module on UCS 5108
lasdcisco
Noticed one of the I/O module keeps showing "Identify" status and is throwing " FSM Retries Exhausted" critical error.  We've tried to reset it using UCS Manager, but did not resolve our issue.  Now we plan on physically reset the I/O module (slide out and slide back in).  Do we have to power down the chassis in order to do so?
Kirk J
Greetings.
You should not need to power down the chassis.
You may need to have TAC check on the UCSM/FI status to make sure there is not some other issue causing the IOM discovery to fail.
Kirk...
Kirk J
Greetings.
Kirk...
thanks Kirk, we're suspecting the cables from the chassis and FI involved I/O module 2s are crossed up somehow, because both I/O module 1s are operating fine.  We will attempt to reset the I/O module before trace out the cables.  Ruling out one thing at a time.
