The connection between C-200 and 6120XP
Burak Atasal
Hi all,
I'll setup a UCS Lab enviroment fot our company.I have 6 x C-200 M2 servers (only with 2x1Gig LOM ports) 2 x 6120XP and couple of blades.I have no problems about connecting blade chassis to 6120.But i have a few questions about connecting C-200 servers to the 6120.
I want to use 1Gig LOM ports for data traffic so i need to use some kind of (or type of) SFP+ to making connection between c-200 to 6120.
or can i do something else.
i dont have any FEX or some other solutions for now.We ordered and waiting for delivery.
2 Accepted Solutions
abbharga
Level 4
Level 4
Hi Burak,
For the C series integration, you need to have the FEX to which the LOM ports connect for the server management and then the 10 gig ports (from a CNA) connect to the 6120 for the data path.
Without the FEX you won't be able to connect them to the 6120.
./Abhinav
Yes that is correct!
Here is URL for the C200 server with the UCSM which will provide you more details:
http://www.cisco.com/en/US/docs/unified_computing/ucs/c/hw/C200M1/install/ucsm-integration.html
./Abhinav
abbharga
Level 4
Level 4
Hi Burak,
./Abhinav
hi Abhinav,
Thanks for your response first.
We dont have the CNA Cards on c-200 so this means LOM ports are the only ports.In this scenerio you say we gonna need CNAs on servers and also FEX for management integration.
correct?
./Abhinav
