UCS C220 M3 raid issue
opnineopnine
hi all,
I have a UCS C220 M3 with 4 hard drives , when I want to create the Raid 5 is not enabled, I only have 1 or 10.
Any ideas?
Thanks.
See this http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/c/hw/C220/install/C220/raid.html#pgfId-1028426
You need the software key, otherwise you will only be able to set up RAID 0,1 and 10
"You can further upgrade this support by adding SAS RAID 5 support with an optional software key. See Installing a Software RAID Key Module for Embedded RAID 5 Support."
HTH,
-Kenny
5 Replies 5
Keny Perez
Level 8
Level 8
What is the CIMC version?
Are you trying to create the RAID from CIMC or WebBIOS?
What is the RAID controller model?
-Kenny
Hello Keny,
I'm doing it with the CIMC, the model is a LSI software Ver C.05 Bios version SCU 11.02151609R
Thanks.
HTH,
-Kenny
Keny,
When you say the software key you mean the full serial from the EXSI?
Thanks.!
No, it is something additional you install for the server that allows you to have RAID 5 available (more info in the link I shared above).
Your Cisco Rep should be able to help you get one.
-Kenny
