UCS C220 M4 - HOT RAID
Good morning to all,
we just purchase an UCS C220 M4-S, but we only have one HDD, we are still waiting for the second one.
I guess there is no problem in start working with VMware and the final VM, and later when the second disk is here make the RAID 1.
Can someone confirm I am right, and there will not be any information lost?
Thanks in advance.
Roberto.
5 Replies 5
Keny Perez
Level 8
Level 8
I think this is not a safe move so you might want to TRY to create the RAID 1 with one disk and see if it is successful, then backup your data when you get the other disk and "rebuild" the array which is actually to "complete" the array...
-Kenny
Do you think it will be possible to create a RAID 1 with only one disk?
I will try it still.
I have seen ppl doing RAID 0 with one disk (RAID 0 not JBOD) :)
Give it a try and let me know.
-Kenny
isaac anish
As per the RAID policy Minimum we required two hardisks for RAID 1 configuration,So if u created array also after rebooting the server it will not work.
