Unable to boot UCS blade from SAN
samtech
I have cloned an existing profile and attached to a B200M3 blade in UCS 5108 chassis. The initiators seems to register fine on SAN. However, unable to see boot LUN's configured.
* There are no local drives
* First boot order is SAN and Second is cd-rom
Any pointers please.
2 Accepted Solutions
Hi @samtech,
This shouldn't be related to SAN as of now, since we can see the LUN clearly under PLOGI session. Please follow the steps I'm attaching(Its for hyper-v but would be same for server edition) to install the FNIC driver during OS installation using driver ISO and let me know if you are able to see the LUN/disk or not.
BTW, what is the BIOS mode? legacy or UEFI? Can you give below output?
During the install (when it asks where to install Windows) try the following:
Format the drive seen in the windows setup
1. press SHIFT-F10 to open a command prompt
2. type 'diskpart'
3. type 'list disk'
Other way would be to use ESXi Cisco custom ISO and try to boot it - see if you are able to see the LUN (Just to confirm if end-to-end everything is good).
MJ
Updates...Booting with ESXi ISO shows boot LUN.
In the mean time I tried the steps as per Windows Server 2016-Install.pdf and was able to see the LUN and install Windows
Great document, however there is one minor error. The section where it points to install the FCoe drive is not under "Network" folder but "Storage folder". Rest of the path is same.
Thanks to everyone for helping me out here..
18 Replies 18
Walter Dey
If you clone your service profile, you will most likely get new (and therefore different) pwwn, nwwn for your vhba ! and this also requires additional zoning entry !
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/ts/guide/UCSTroubleshooting/UCSTroubleshooting_chapter_0110.html
https://community.cisco.com/t5/data-center-documents/troubleshooting-boot-from-san-installation/ta-p/3155048
Hi Walter
Thanks for your response. I have reconfigured zoning with new WWPN's and the initiators have also registered on SAN.
Are you planning on using the same exact storage lun for the cloned service profile?
If not, you will need to create an additional LUN, and follow the steps Walter already outlined, including LUN masking/permissions for the individual boot LUNs.  You generally do not want more than one set of initiators accessing a single boot LUN.
It would be helpful to understand what you are trying to accomplish with your 'clone'....
Kirk...
Okay.. this is what I've done
Deleted cloned profile.
Created a new profile using template (2HBA's and 1 NIC)
Boot order: 1st SAN and 2nd CD_ROM
Associated profile with the spare blade
Zone WWPN of HBA 1 with MDS-A and WWPN of HBA 2 with MDS-B (Both Initiators have registered within SAN)
Registered Initiators with server hostname and IP (which I am planning to provision to this blade)
Created new LUN 200GB
Created New Storage Group. Added both server and New LUN to this storage group (LUN MASKING)
However, when the server is booted it does not detect 200GB LUN. Therefore unable to find boot device.
Note: I have recently upgraded firmware to 2.2 8L. Don't want to confuse things but would this have anything to do with this?
I just had a look in BIOS (Boot Order) and it is showing the WWPN of target (First two). However it has "WWPN Target:000). Is this how it should appear?
Also, I am not sure what the bottom two are.
I believe those are to represent the LUN mask (in this case it appears to be 0, so we are looking for the LUN masked as 0).
If you still have the server in a failed to boot state, can you run the below and provide the output?
connect adapter [chassis #]/[blade #]/1
connect
attach-fls
lunlist
*Edit (Saw this output on another thread in this discussion).
adapter 1/1/1 (fls):2# lunlist 13
vnic : 13 lifid: 3
- FLOGI State : flogi est (fc_id 0x270302)
- PLOGI Sessions
- WWNN 50:06:01:69:3e:e0:3e:9e WWPN 50:06:01:69:3e:e0:3e:9e fc_id 0x270600
- LUN's configured (SCSI Type, Version, Vendor, Serial No.)
LUN ID : 0x0000000000000000 (0x0, 0x4, DGC , FCN00131500079)
- REPORT LUNs Query Response
- WWNN 50:06:01:60:3e:e0:3e:9e WWPN 50:06:01:60:3e:e0:3e:9e fc_id 0x270500
- Nameserver Query Response
- WWPN : 50:06:01:60:3e:e0:3e:9e
- WWPN : 50:06:01:69:3e:e0:3e:9e
This output looks good from what I can see, the section highlighted above tells me that from the server's perspective it can see the LUN.
What OS are you trying to install? Does the OS include the appropriate drivers for the adapter?
Niko
I am trying to install Server 2016. However upon booting from ISO, unable to see any LUN's\drives attached to install OS
This document might be useful: https://cdn.cnetcontent.com/5a/1f/5a1f3f3e-d3a0-49c8-bbf9-88676f31ea2d.pdf
Cisco UCS B-Series Blade Servers Windows Installation Guide
First Published: April 22, 2011
Last Modified: March 20, 2015
Why are you using fcalias ? I would use device alias ?
Hi Walter
Thanks for helping me in this. However, I dont understand the difference between fcalias and device alias. fcalias is only referring to WWPN of the HBA. I will go through the steps in the pdf guide. Is there any difference in installing windows as compared to hypervisor? On a separate occasion earlier when I had installed ESXi, setup was able to detect the LUN unlike this time.
do you also have a zone with the vhba pwwn and the storage pwwn….
please provide the following information from both MDS
- show fcns database vsan xyz
- show flogi database vsan xyz
plus all the zone, zoneset information for this UCS vhba and the storage system.
Hi Walter
Please find attached output of both commands on MDS A & B
Thanks !
Do you see the flogi ( pwwn ) of the vhba which should initiate the boot ? is the vhba in vsan 10 resp. 20 ?
And please show me the corresponding zone and zoneset.
MDS A zone info
zone name VBT01-HBA0_VNX01-SPA0 vsan 10
fcalias name VNX01-SPA0 vsan 10
pwwn 50:06:01:60:3e:e0:3e:9e
fcalias name Veeam-HBA0 vsan 10
pwwn 20:10:00:25:b5:0a:00:ff
zone name VBT01-HBA0_VNX01-SPB1 vsan 10
fcalias name VNX01-SPB1 vsan 10
pwwn 50:06:01:69:3e:e0:3e:9e
MDS B zone info
zone name VBT01-HBA1_VNX01-SPB0 vsan 20
fcalias name VNX01-SPB0 vsan 20
pwwn 50:06:01:68:3e:e0:3e:9e
fcalias name Veeam-HBA1 vsan 20
pwwn 20:10:00:25:b5:0b:00:8f
zone name VBT01-HBA1_VNX01-SPA1 vsan 20
fcalias name VNX01-SPA1 vsan 20
pwwn 50:06:01:61:3e:e0:3e:9e
Where it says fcalias name Veeam, it used to be VBT01. But, had to delete that with old profile and then created alias with the new name and WWPN
Zoneset: MDS-A
Zoneset: MDS-B
