What is Cisco’s recommendation to connect FI to both SAN ?
sachinc01
Hi Team,
My client  is recommending to connect each FI to both SAN switches ?
but my concern is
Device :- UCS5108
Please guide on it
10 Replies 10
Wes Austin
Based on your very limited description and question, here is a design guide for UCS and MDS SAN switches.
https://www.cisco.com/c/en/us/products/collateral/storage-networking/mds-9500-series-multilayer-directors/white_paper_c11_586100.html
Walter Dey
The recommended FC fabric design is; dual physical fabric;
Fabric-interconnect-A - MDS-A
Fabric-interconnect-B - MDS-B
No cross FC connections !!
Ok Thanks Sir,
What is about Network Switches to Fi connectivity ?
Diagram 1:-
Description: Description: cid:image003.jpg@01D3C5DB.A49E3DE0
You min below diagram 2 is wrong as per cisco recommendation.. Sir Any
reason for that please mention..
Diagram 2
Description: Description: cid:image004.png@01D3C5DB.A49E3DE0
For network switches, typically customers with connect both FI to both upstream network switches. If using Cisco Nexus, you can configure vPC.
If you are using third party switches you would have to explore their HA options.
SAN switches should only connect to a single Fabric Interconnect, A or B.
Thanks Sir,
Any reason for that please mention .(If any Network slandered or rule please
mention )
You should differentiate between classical FC or FCoE and Ethernet. For FC and FCoE dual fabric design is state of the art since 20+ years; any storage Company like EMC, IBM, HP, NetApp recommends this design.
FCoE Uplink with virtual Port Channel (vPC)
https://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-manager/116188-configure-fcoe-00.html
Dear Sir,
Thanks for your Support!!!
Generally considered bad SAN design, But Customer asking why this is bad
design? What is impact of this design ?
Please give me satisfied suggestion then I will told this to customer.
Description: cid:image002.png@01D3C8E5.87415C70
I'm sure this customer is a Ethernet / IP Person, who doesn't understand FC design.
Think about your VSAN design; in contrast to Ethernet, where each Vlan exists on both fabrics, on FC you would design different VSAN's for fabric A, resp. B. This is how you achieve dual fabric separaration; if there is a issue on a fabric, eg. zoning, the other fabric is still working ok; and think about Firmware upgrade; can be done per fabric, therefore Multipathing FC software on the host will handle this automatically without downtime.
How would you design your VSAN's if the UCS FI would be dual homed to Northbound MDS ? the same VSAN has to exist on both fabrics ? and each vhba can only be in one VSAN; therefore you follow the Ethernet design, where each vhba in fabric A and B is in the same VSAN; your multipathing software will therefore see double the number of paths;  Troubleshooting becomes a nightmare.
The claim of the storage vendors: to achieve 99.9.. % availability, you Need a dual FC fabric.
Dear Sir,
Client Requirement is for Splitter cable :-
& our distributor is following cable in stock, Which cable is match for
client Requirement Please guide..
Dell Networking, Cable, QSFP+ to QSFP+, 40GbE Passive Copper Direct Attach
Cable, 3 Meter Ex stock.
Cable, 5 Meter Ex stock.
Dell Networking ,Cable,40GbE (QSFP+) to 4 x 10GbE SFP+ Passive Copper
Breakout Cable, 3 Meters Ex stock.
Breakout Cable, 5 Meters
Dear Sir,
- QSFP-4SFP10G-CU3M QSFP to 4xSFP10G Passive Copper Splitter
Cable, 3m
