ericwill
The following Cisco UCS Platform Emulators are available for download from Cisco:
Current Cisco UCS Platform Emulators
CONFIGURATION IMPORT NOTE:  Importing configuration backups (All, System, or Logical) taken from the UCS Platform Emulator (UCSPE) to physical UCS Manager domains is not recommended or supported by Cisco TAC.  UCSPE backups should only be imported to UCSPE domains.
Cisco UCS Platform Emulator 4.2(2aPE1) - UCS 62xx/63xx/64xx Fabric Interconnect, C4200, S3260, Mini:
Downloads:
MD5 hashes for downloads:
  • ZIP: b390bbf1d783532194141c9b7bff6d64
  • OVA: 1577b7b88b7287b707fea9995c5f0135
Cisco dCloud Programmability Demo using the UCS Platform Emulator
  • UCSPE is featured in a Cisco dCloud programmability demo.   The demo includes a comprehensive lab guide for programming using the Cisco UCS PowerTool and Python SDK.
Video demos of the Emulator
Previous Releases:
Cisco UCS Platform Emulator version 4.1(2cPE1):
Downloads:
Cisco UCS Platform Emulator version 4.0(4ePE1):
Downloads:
Cisco UCS Platform Emulator version 3.2(3ePE1):
Downloads:
Documentation:
Cisco UCS Platform Emulator version 3.1(2ePE1):
Downloads:
Documentation:
Cisco UCS Platform Emulator version 3.1(2bPE1) - UCS Classic, Mini, and C3260:
Downloads:
Documentation:
Cisco UCS Platform Emulator version 3.1(1ePE1) - UCS Classic, Mini, and M-Series:
Downloads:
Documentation:
Cisco UCS Platform Emulator version 3.0(2cPE1) - UCS Mini:
Downloads:
  • Download UCSPE 3.0(2cPE1) OVA or ZIP (Requires Cisco.com login)
  • UCS Platform Emulator Firmware Bundles (includes firmware meta-data only)
    • NOTE:  From UCS PE 2.2(1bPE1) onwards, UCS PE supports uploading the B-Series and C-Series server firmware bundles.  Because of the large file sizes of the firmware bundles, UCS PE only supports uploading of only the stripped-down versions (attached to this document), which includes only the firmware metadata but not the actual firmware itself in the binaries.  The stripped-down version of the firwmare bundles which contain metadata only of the B-series and C-series server firmware is reduced to approximately 50 kB in size.
Documentation:
Cisco UCS Platform Emulator version 2.5(2aPE1) - UCS M-series:
Downloads:
  • Download UCSPE 2.5(2aPE1) OVA or ZIP (Requires Cisco.com login)
Documentation:
Cisco UCS Platform Emulator version 2.2(5aPE1) - UCS Classic:
Downloads:
  • Download UCSPE 2.2(5aPE1) OVA or ZIP (Requires Cisco.com login)
Documentation:
Archived Cisco UCS Platform Emulators
Cisco UCS Platform Emulator version 3.0(1cPE1):
Downloads:
  • Download UCSPE 3.0(1cPE1) OVA or ZIP (Requires Cisco.com login)
Documentation:
Cisco UCS Platform Emulator version 2.5(1aPE1) - UCS M-series:
Downloads:
  • Download UCSPE 2.5(1aPE1) OVA or ZIP (Requires Cisco.com login)
Documentation:
Cisco UCS Platform Emulator version 2.2(4bPE1) - UCS Classic:
Downloads:
  • Download UCSPE 2.2(4bPE1) OVA or ZIP (Requires Cisco.com login)
Documentation:
Cisco UCS Platform Emulator version 2.2(3aPE1) - UCS Classic:
Downloads:
  • Download UCSPE 2.2(3aPE1) OVA or ZIP (Requires Cisco.com login)
Documentation:
Cisco UCS Platform Emulator version 2.2(2cPE1):
Downloads:
  • Download UCSPE 2.2(2cPE1) OVA or ZIP (Requires Cisco.com login)
Documentation:
Cisco UCS Platform Emulator version 2.2(1bPE1):
Downloads:
  • Download UCSPE 2.2(1bPE1) OVA or ZIP (Requires Cisco.com login)
Documentation:
Cisco UCS Platform Emulator version 2.1(3aPE1):
Downloads:
Documentation:
Cisco UCS Platform Emulator version 2.1(2aPE1):
Downloads:
Documentation:
Cisco UCS Platform Emulator version 2.1(1aPE3):
Downloads:
Documentation:
Cisco UCS Platform Emulator version 2.0(1mPE1):
Downloads:
Cisco UCS Platform Emulator version 1.4(1aPE1):
Downloads:
Documentation:
Cisco UCS Platform Emulator version 1.3(1aPE1):
Downloads:
aleks00011
Any news on this? seeing the same thing with version UCSPE_3.1.1e, F0856 Activation failed and Activate Status set to failed for the IOM2208XP
dsoper
Hi Aleks,
Are you seeing any functionality problems with the emulator?  These turned out to be spurious warnings in the previous case that didn't cause other issues.
aleks00011
Hi David
Thanks for replying,
So far no issues but it makes you question any problems you do encounter.
Would be nice if the simulator would come up clean.
int.Shehroze.Asghar
Community Member
The download stops in the middle about 2.5MB. Whats the issue????
dsoper
If you’re having issues downloading the OVA or Zip file, please try the cisco.box.com links in the Box_Download_Links.txt.zip file.
Thanks.
derek.small
Level 5
Level 5
Is there some trick to getting the FIs to actually change?  I'm using 3.1.2 PE, and am trying to build a UCS mini.  I've been able to remove all the hardware that the system had be default, then I go into settings to change the FIs to 6324s, but when I click on the submit button nothing happens, and I still have 6332 FIs listed as my FIs.  They are showing green, but I have not found a way to get them to show red before trying to swap them.  I've also tried other FIs, but have the same result.
dsoper
After clicking submit the UCSPE should restart which will take several minutes to complete. Are there any messages on the VM console that indicate a reset is occurring after clicking submit?
Thanks-
David
na-is-infrastructure-alerts
Community Member
I have exported my production configuration (logical) and when I try to import it into UCEPE 3.1(1e) I receive the following error message: Insufficient privileges to configure 'org-root/ls-<server name removed>'. User's privileges must have at least one of 'read-only', but user has 'admin'
dsoper
Does the import FSM tab show any other information on what is not working with the import? If you can directly reply to me and include the backup file, I can take a look at the specific objects that are failing the import.
Thanks.
jzitcovi
When will UCSPE version 3.2.1 be available?
amr_gritly
i installed uUCSPE_3.1.2e  VM  successfully but  everytime i try  to access the GUI website , it failes , any help!
claranan
Has UCSPE 3.2.1 been release yet?  If not, is there a scheduled release date?
mkoch
Level 4
Level 4
still no news on a 3.2 PE?
tndmcclain
I have installed the emulator on a laptop running VMware workstation player.  I am not able to access the gui.  I can only access the cliuser or config options.  Any help would be great.
Thank you
Dave
towagner
So what happens when you try to launch the GUI? Does it time out? Error screen? Also, have you tried doing the factory reset? Finally, what browser are you using? I’ve found Firefox works most consistently.
-Todd
(sent from mobile)
