Factory Reset?
kg6itcraig
We are changing a 6120 UCS to a new role in life, and would like to do a factory reset (wipe) of the device.
Anyone privy on doing that?
Thanks!
Craig
My UCS Blog http://realworlducs.com
jdrurycisco
SSH to your 6120
connect local-mgmt
erase configuration
This will reset the 6120 to factory defaults after a reboot.
lwatta
login to the 6120 via ssh or serial port and login as admin
connect local-mgmt
erase configuration
that will reboot the box and bring it back to the setup prompt. If you have two 6120s in a cluster make sure you run it on both.
louis
