UCS B / UCS manager Upgrade 1.3 to 2 issues
hans.velez
hi everyone,
i'm having issues with the download of the image to the fabric interconnect, in event file goes this message
Description: [FSM:STAGE:STALE-FAIL]: deleting downloadable ucs-k9-bundle-infra.2
.0.3a.A.bin on local(FSM-STAGE:sam:dme:FirmwareDownloaderDownload:DeleteLocal)
Affected Object: sys/fw-catalogue/dnld-ucs-k9-bundle-infra.2.0.3a.A.bin
Trigger: Special
User: internal
Cause: Transition
Code: E4195295
Creation Time: 2012-07-12T20:36:19.006
Description: [FSM:STAGE:REMOTE-ERROR]: Result: end-point-failed Code: unspecifie
d Message: End point timed out. Check for IP, password, space or access related
issues.
(sam:dme:FirmwareDownloaderDownload:DeleteLocal)
Trigger: Special
User: internal
Cause: Transition
Code: E4195295
Creation Time: 2012-07-12T20:36:18.995
Description: [FSM:STAGE:FAILED]: downloading image ucs-k9-bundle-infra.2.0.3a.A.
bin from 10.8.224.244(FSM-STAGE:sam:dme:FirmwareDownloaderDownload:Local)
Trigger: Special
User: internal
Cause: Transition
Code: E4195293
i had a SFTP / SCP seber on the same network of the fabric, but i can't get done the download. the server is a host/PC, no antivirus and firewall that cant block the transmission on the side of the host/PC
any ideas??
thanks for your help!
Hi Hans,
You can follow guide to upgrade UCS manager from following link. Check that you are doing correct steps.
http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/upgrading/from1.3/to2.1/b_UpgradingCiscoUCSFrom1.3To2.1.html
6 Replies 6
abbharga
Level 4
Level 4
Hi Hans,
A few things to check:
* Do you have any previous job for the same destination host ip in the download section? If so can you delete it and try again?
* And have you made sure there are no space issue on the FI / the username-password is correct?
* In case this STFP / SCP client has not worked for you can you try using an alternate protocol and client? e.g. tftf with using the tftpd32.exe as the client.
./Abhinav
Hi Abhinav,
bout the things you say to check:
  • YES, WE HAVE OLDER TASK FOR DOWNLOAD AND WE EREASE IT ALL AND DON'T WORK
  • MAYBE IN THIS ITEM WE DON'S HAVE ENOUGH INFO WE GOT THIS FROM DE FI (THE FILE SIZE WE ARE TRAYING TO SEND IS 550 MB):
ucs1-A /fabric-interconnect # sh storage
Storage on local flash drive of fabric interconnect:
    Partition        Size (MBytes)    Used Percentage
    bootflash         8785                          10
    opt                 1916                           2
    workspace        277                           2
ucs1-A /fabric-interconnect # sh environment
Fabric Interconnect A:
    Operability: Operable
    Fabric Card 1:
        Threshold Status: N/A
        Overall Status: N/A
        Operability: N/A
        Power State: N/A
        Thermal Status: N/A
        Voltage Status: N/A
    Fabric Card 2:
        Overall Status: N/A
        Operability: N/A
        Power State: N/A
        Thermal Status: N/A
        Voltage Status: N/A
ucs1-A /fabric-interconnect # sh detail
Fabric Interconnect:
    Product Name: Cisco UCS 6120XP
    PID: N10-S6100
    VID: V01
    Vendor: Cisco Systems, Inc.
    Serial (SN): SSI144906KJ
    Revision: 0
    Total Memory (MB): 3549
    OOB IP Addr: X.X.X.X
    OOB Gateway: X.X.X.X
    OOB Netmask: X.X.X.X
    Current Task:
  • We are trying the upgrade with a siftware bundle (550 MB), TFTP has a file size limitation of 32 MB. The firmware bundles can be much larger than that.
http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/upgrading/from1.3/to2.0/b_UpgradingCiscoUCSFrom1.3To2.0_chapter_011.html#task_C8E850B883D741BFBEF0FBBA409C6CB7
Hi Hans,
On the client you are using to upload the file, do you see a request coming from the FI or three is no request at all?
In case there is no option to see the client request you can run wireshark or something to check for the request coming in.
If this is holding your upgrade activity, feel free to open a TAC case and we should be able to help you.
./Abhinav
tsantoyoc
Hi Hans,
Were you able to solve this issue?
I'm having the same problem upgrading from UCS 1.3 to 2.1, but it seems like the traffic never goes to the tftp server but i don't have firewalls or any device stopping the traffic.
Hi Hans,
hans.velez
Hey Tobias,
we were reviewing the FI upgrade in stand alone mode and was not the best way, put it in another cluster with FI and upgrade goes fine
