Integrating Voice and Data pri with MGCP
VON CLAWSON
Level 3
Level 3
I know this can be done with the following configuration:
controller T1 1/1
framing esf
linecode b8zs
channel-group 1 timeslots 1-12 speed 64
pri-group timeslots 13-24
However, I cannot seem to find documentation on it on www.cisco.com. Any help would be appreciated.
Von
Please rate if this helps.
5 Replies 5
VON CLAWSON
Level 3
Level 3
Can anyone help me with this?
If you telco can provision that, there is no problem, MGCP won't even know what are the unused PRI timeslots for.
right, I know that it will work. What I need is some official documentation indicating that it will work and is supported.
Cisco does so many things that is not that you can find confirmation about each and any variation in configuration.
What you want to do is really nothing special and works since some 10 years now. Some people calls it "integrated T1 access"
ATT calls it SINA Prime digital service.
controller T1 0/0/0
framing esf
linecode b8zs
ds0-group 2 timeslots 13-24 type e&m-wink-start dtmf dnis
