10-18-2012 01:08 AM
Scenario is:
I have a cisco router 2811 with NM-HDV that I use it as a voice gateway. 8 PSTN lines and one E1 - PRI are connected to this router which this router has to pass them on SIP to asterisk server.
FXO ports work well, and the other hand everything thing about E1 port seem to be ok due to it can handle ring either inbound or outbound but unfortunately voice between them is one-way for instance when I make call from outside to E1 number after pick up from inside, voice inside can’t be hear from outside.
I have error on my E1 controller, SLIP error increase specially.
And the other hand whan i want to config encapsulation ppp on my serial E1 i can not do it
SIPxchangeGW(config)#interface serial 1/0/0:15
SIPxchangeGW(config-if)#encapsulation ppp
%Hardware does not support ISDN data calls; encapsulation not set.
my E1 voice call is :NM-HDV
My configuration is :
version 12.4
service nagle
service timestamps log datetime
hostname SIPxchangeGW
boot-start-marker
boot system flash c2800nm-ipvoicek9-mz.124-5.bin
boot-end-marker
logging console informational
no aaa new-model
resource policy
clock timezone IRST 3 30
clock summer-time IRST recurring
network-clock-participate slot 1
voice-card 0
no dspfarm
voice-card 1
no dspfarm
ip cef
no ip domain lookup
isdn switch-type primary-net5
template mon
no voice call carrier capacity active
voice service voip
sip
username navid privilege 15 secret 5 $1$dBqi$RmzGUV1Fgo/Jo4jzEhpnH1
username kamran privilege 15 secret 5 $1$9TmB$h0sW4W7LHjhEROoKF3ylB.
archive
log config
hidekeys
controller E1 1/0/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 1/0/1
shutdown
interface FastEthernet0/0
ip address 192.168.210.20 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0/0:15
ip unnumbered FastEthernet0/0
encapsulation hdlc
dialer idle-timeout 500000
isdn incoming-voice modem 64
no cdp enable
interface Group-Async0
physical-layer async
no ip address
encapsulation slip
no ip route-cache
no group-range
no ip classless
no ip http server
no ip http secure-server
no cdp run
control-plane
voice-port 0/0/0
connection plar 104
voice-port 0/0/1
supervisory disconnect anytone
output attenuation -3
echo-cancel coverage 32
compand-type a-law
cptone GB
timeouts call-disconnect 5
timeouts wait-release 5
connection plar 105
impedance complex2
description ***Konoba 345713***
caller-id enable
voice-port 0/0/2
connection plar 106
voice-port 0/0/3
connection plar 107
voice-port 0/1/0
signal groundStart
cptone DE
connection plar 100
impedance complex2
caller-id enable
voice-port 0/1/1
connection plar 101
caller-id enable
voice-port 0/1/2
connection plar 102
voice-port 0/1/3
connection plar 103
voice-port 1/0/0:15
input gain 4
output attenuation -6
echo-cancel coverage 24
no vad
cptone DE
bearer-cap Speech
no mgcp timer receive-rtcp
dial-peer cor custom
dial-peer voice 102 voip
destination-pattern 102
session target sip-server
codec g711ulaw
dial-peer voice 103 voip
destination-pattern 103
codec g711ulaw
dial-peer voice 104 voip
destination-pattern 104
codec g711ulaw
dial-peer voice 105 voip
destination-pattern 105
codec g711ulaw
dial-peer voice 106 voip
destination-pattern 106
codec g711ulaw
dial-peer voice 107 voip
destination-pattern 107
codec g711ulaw
dial-peer voice 101 voip
destination-pattern 101
codec g711ulaw
dial-peer voice 11001 pots
preference 1
destination-pattern .T
direct-inward-dial
port 1/0/0:15
forward-digits 11
dial-peer voice 100 voip
destination-pattern 100
codec g711ulaw
dial-peer voice 11002 voip
session protocol sipv2
dtmf-relay rtp-nte
codec g711ulaw
sip-ua
sip-server ipv4:192.168.210.9:5060
alias exec his show call history voice br
alias exec scb show call active voice br
alias exec code1 show call active voice | i CodecBytes=
alias exec cpu show proces cpu his
alias exec actt show voice call sum
alias exec ac show call active voice brief
alias exec hi show call history voice brief
alias exec acip show call active voice brief | incl IP
alias exec acdur show call active voice brief | incl dur
alias exec hidur show call history voice brief | incl dur
alias exec hiip show call history voice brief | incl IP
alias exec acp show call active voice brief | incl Tele
alias exec hip show call history voice brief | incl Tele
alias exec sd show dial-p voice summary
alias exec zv show call active voice brief | incl Orig
alias exec hizv show call history voice brief | inc
alias exec iac sh isdn active
alias exec e1 show call active voice br | in
alias exec e2 show voip rtp connections
line con 0
logging synchronous
line aux 0
line vty 0 4
exec-timeout 0 0
logging synchronous
login local
scheduler allocate 20000 1000
ntp clock-period 17179672
ntp source FastEthernet0/0
ntp server 192.168.210.7
end
--More--
Scenario is:
my configuration is :
10-18-2012 10:12 AM
Use the command network-clock-select for SLIP problem and try this config for serial interface:
*** voice config, no data ***
no ip address
encapsulation hdlc
no logging event link-status
no snmp trap link-status
isdn overlap-receiving T302 4000
isdn incoming-voice voice
isdn map address transparent
isdn send-alerting
isdn negotiate-bchan
isdn sending-complete
no isdn outgoing display-ie
no cdp enable
Regards.
10-21-2012 08:42 AM
Thank's Daniele for your answer but unfortunately my problem still exist same as before. the serial of the router was configured exactly like your suggestion.when i call from inside to outside, outside sound can be heard from inside but the sound of inside it isn't heard by inside . Please help me for solving this problem as soon as possible.
10-22-2012 12:33 PM
Add the output of "debug ccsip message" and "debug voice ccapi inout".
Regards.
