Temporary Failure (41) Code
marman
Level 2
Level 2
We are getting the "temporary failure (41)" cause code on some calls - can anyone explain what this means.
Cheers
6 Replies 6
Chester Rieman
This generally means that one or more of the resources needed to complete the call is not availible. (DSPs, bearer channels, ip connectivity are resources that can cause this if they are unavailible).
Hope this helps.
We have had problems with DSP`s on the router and i was going to upgrade the code to a new version to see if that helps. We aren`t losing any Ip connectivity as the interfaces stay up - could it be related to QoS parameters?
Thanks for your help
BTW - this is a sample of a call which drops out. It seems to bevery random indeed
2772 : 24366195hs.4090 +361 +1609 pid:35 Originate 359352519
dur 00:00:12 tx:448/8797 rx:408/7819 29 (temporary failure (41))
IP 10.35.10.1:18496 rtt:531ms pl:4460/240ms lost:0/2/0 delay:53/53/70ms g729r8
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
2772 : 24365528hs.4091 +1029 +2316 pid:6 Answer
dur 00:00:12 tx:408/7819 rx:567/11177 29 (temporary failure (41))
Telephony 4/0/1 (4092) [4/0/1] tx:8060/6130/0ms g729r8 noise:-65dBm acom:50dBm
uniemeyer
Level 3
Level 3
what type of router and IOS do you use?
If it is a C3745 you can try the 12.3(6c) IP Plus, which we found is the most stable apart
from a crash bug.
regards Ulrich
UM
Alexandre11
Level 5
Level 5
I'm also experiencing this problem, AT THIS incoming links showing
"(41) Temporary Failure"
No Router
dial-peer voice 10000 pots
 description Entrantes Pela E1 0/0/0
 incoming called-number .
 no digit-strip
 direct-inward-dial
 port 0/0/0:0
dial-peer voice 10001 pots
 description Entrantes Pela E1 0/0/1
 no digit-strip
 direct-inward-dial
 port 0/0/1:0
Any suggestions?
Jon Clark1
Level 4
Level 4
I ran into this same error code in June 2019 CUCM 10.5.2.
This error code is very generic and is basically useless.
Problem: No one could call a new user. Rang a few times then fast busy. Error Code SIP/2.0 480 Temporarily Not Available.
After wasting many hours troubleshooting "network connectivity" issues it turns out that someone checked the "Call Forward Unregistered" checkbox on the user's DN. The user had a Jabber CSF setup (didn't even know it) and it was unregistered thus forcing all calls to Voicemail.  The user had a no Voicemail Profile in place and the default profile was to block access to voicemail. All calls to the user would ring then fast busy.
Once I gave the user a good voicemail profile then calls to the unregistered CSF rang through to voicemail.
