VOIP call, no more than 3 calls, why
r-castanon
I've a 1760-V router conected to a PBX (Harris), the problem is I can do only 3 calls at a time, the call 4 doesnt get started, Ive 4 DSP and using Codec g729, at least 8 call could be at the same time.
The main conf is:
tdm clock E1 0/0 both export line
voice service voip
h323
voice class codec 2
codec preference 1 g729r8 bytes 50
controller E1 0/0
framing NO-CRC4
ds0-group 1 timeslots 1-15,17-19 type r2-digital dtmf dnis
cas-custom 1
country telmex
voice-port 0/0:1
echo-cancel coverage 32
cptone MX
timeouts wait-release 3
dial-peer voice 1490 voip
destination-pattern 7490
voice-class codec 2
session target ipv4:10.8.1.1
ip qos dscp cs3 media
ip qos dscp cs3 signaling
no vad
dial-peer voice 1491 voip
destination-pattern 7491
voice-class codec 2
session target ipv4:10.9.1.1
no vad
dial-peer voice 3000 pots
destination-pattern 30..
port 0/0:1
prefix 30
The version is:
Cisco IOS Software, C1700 Software (C1700-IPVOICE-M), Version 12.3(7)XR, RELEASE SOFTWARE (fc1)
I'll apreciate your hep
Rene Castañon (MEXICO)
7 Replies 7
Chester Rieman
Check here:
http://cisco.com/en/US/products/hw/routers/ps221/prod_configuration_guide09186a0080106d1c.html
Also check the dsp resource calculator on this page.
Thanks for your help, I'd read that document and also used the DSP calculator thats why I think that at least 8 calls could be running at the same time (Im using 4 DSP's, PVDM-256K-4 + PVDM-256K-12), the interface to PBX is VWIC-1MFT-E1 and configured as ds0-group 1 timeslots 1-15,17-24 type r2-digital dtmf dnis
WE can't use other Codec like g711 because remote partners have not enough bandwith available, but with 8 calls running at this main pint will be enough.
A'll appreciate if you have somethin else
Rene C
you might want to try some debugs to see what is happening try debug vpm dsp and debug vpm error for a start
Richard
This is what I found when debug vpm dsp & vpm error were enabled (Ican't find the code meaning):
LINV01#
LINV01#
Oct 14 18:42:13.678: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x0 timestamp=29345 systime=16985830
LINV01#
Oct 14 18:42:41.095: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0xC timestamp=56813 systime=16988576
LINV01#
Oct 14 18:42:53.647: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x8 timestamp=3857 systime=16989833
LINV01#
Oct 14 18:43:16.647: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0xC timestamp=26901 systime=16992137
LINV01#
Oct 14 18:43:25.467: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x8 timestamp=35737 systime=16993020
LINV01#
Oct 14 18:45:32.375: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x0 timestamp=30169 systime=17005570
LINV01#
Oct 14 18:45:48.839: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x0 timestamp=46661 systime=17007218
LINV01#
Oct 14 18:45:56.539: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0xC timestamp=54373 systime=17007989
LINV01#
Oct 14 18:46:02.062: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x0 timestamp=5907 systime=17008542
Oct 14 18:46:02.210: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x8 timestamp=60049 systime=17008557
LINV01#
Oct 14 18:46:03.867: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x0 timestamp=61628 systime=17008723
LINV01#
Oct 14 18:46:05.940: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x8 timestamp=63785 systime=17008930
LINV01#
Oct 14 18:46:10.086: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x0 timestamp=2292 systime=17009345
LINV01#
Oct 14 18:46:14.740: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x8 timestamp=6976 systime=17009811
LINV01#
Oct 14 18:46:16.645: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x8 timestamp=8888 systime=17010002
LINV01#
Oct 14 18:46:28.479: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x0 timestamp=20738 systime=17011187
LINV01#
Oct 14 18:46:41.777: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x0 timestamp=6703 systime=17012518
LINV01#
Oct 14 18:46:43.790: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x0 timestamp=6743 systime=17012720
LINV01#
Oct 14 18:46:45.803: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x0 timestamp=14951 systime=17012921
LINV01#
Oct 14 18:46:47.784: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x0 timestamp=6823 systime=17013119
LINV01#
Oct 14 18:46:48.804: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x8 timestamp=41066 systime=17013222
LINV01#
Oct 14 18:47:08.033: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x8 timestamp=60421 systime=17015147
LINV01#
Oct 14 18:47:09.034: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x8 timestamp=61425 systime=17015247
LINV01#
Oct 14 18:47:16.705: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0xC timestamp=3474 systime=17016015
LINV01#
Oct 14 18:47:28.692: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x8 timestamp=15486 systime=17017215
LINV01#
Oct 14 18:47:37.388: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0xC timestamp=24206 systime=17018086
LINV01#
Oct 14 18:47:47.597: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x8 timestamp=34410 systime=17019109
i have seen something similar to this once, and it had to do with a bad dsp chip. the system doesn't always tell you when a dsp chip goes bad, it just limits you abiliy to place calls over those dsps. there are dsp test commands (some are actually hidden) that will run some kind of loopback test on all your dsp chips in the system. just remember to have " term mon" on if you are doing this remotely.
let's know how it turns out.
E.
sriram.g
Try the voice-card command under global config and add the codec complexity as medium under that. This may help.
GS
