911 dialing
mdube
Hey guys,
Quick (and stupid) question regarding dialing 911
If we have the following config :
dial-peer voice 58 pots
trunkgroup ALL_T1E1
corlist outgoing call-emergency
description **CCA*North American-10-Digit*Emergency**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 3
destination-pattern 9911
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_T1E1
preference 3
destination-pattern 911
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-rule 1112
rule 1 /^9/ //
Does it means that if I dial 911 only (not 9911) it will call outside?
This is something kind of hard to test, and as I am unsure, I prefer to check this out before telling the client what to write in their emergency plan.
Thanks guys!
P.S. a chatroom would be nice for those questions
2 Accepted Solutions
Yes, that is a CCA generated config.
911 OR 9911 will work.
EDIT: I should mention -- it is always best practice to do an ACTUAL 911 test call. These can generally be scheduled by calling the non-emergency line first if you are concerned about being fined for non-emergency calls. (Though I've found they are generally very understanding about it as long as you state right away that it is a test call and you do not have an emergency)
Please rate helpful posts.
Paul Dicine
You can also do a translation rule test without having to actually dial 911. Go to Monitor ->Telephony -> Translation Profiles and you can see the results to make sure it's working O.K.
mdube
Anyone?
It is my understanding that 911 would "go out" and dial 911 directly, but of course, dialing 911 is kinda wrong just to test it out...
Paul Dicine
