02-09-2012 08:04 PM - edited 03-21-2019 05:19 AM
Like the title says I'm looking for a user guide for a customer who has a cordless phone on a uc540 FXS port. They want to use some of the features available through the link/hookflash button. I can't seem to find an easy guide.
Any help would be appreciated
Thanks!
Solved! Go to Solution.
02-10-2012 01:40 PM
Hi Daniel,
You can try this standard feature codes:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmefacs.html
Best regards,
Alex
*Please rate helpful posts.
02-10-2012 08:03 AM
Hook flash is only configurable via CLI not CCA so they wouldnt be able to use that feature on the IP Phones. The cordless phones should be able to use hook flash if the call has already been connected. That feature set should come with the phone manual. There are feature access codes where you can do call forward all and park but im not sure if that's what you are looking for.
02-10-2012 01:26 PM
Yes that is what I'm looking for however it's a Panasonic cordless phone attached to the FXS port which obviously does not come with a manual for hookflash features on a Cisco UC540.
Thanks!
02-10-2012 01:40 PM
Hi Daniel,
Best regards,
Alex
02-10-2012 01:49 PM
Cool thanks for finding it for me......
Dan
