07-20-2011 09:56 AM - edited 03-21-2019 04:22 AM
Today we are releasing the Limited Deployment (LD) release of UC320W 2.0.13(2) firmware. This release is available only via the Cloud by installing the attached PMF. There are no release notes for this firmware version. This is the 2.0.9(3) firmware with several key fixes added:
This release contains only the above fixes. Those customers who are experiencing any of the above problems are encouraged to install the attached PMF that will allow them to upgrade to 2.0.13. When the 2.1 feature release is made available in August you are requested to upgrade to 2.1 when convenient.
Today, by installing the attached PMF on your UC320W.
If your WAN is connected you should see a pop up dialog appear shortly, offering you the 2.0.13(2) firmware upgrade.
07-25-2011 09:28 AM
This fixed the DMTF issue for both boxes! Thanks a ton.
07-25-2011 08:34 PM
I can confirm this as well. Thanks to the whole team on delivering this fix.
07-26-2011 01:00 AM
This has also fixed my SIP trunk on hold issue. Thanks for the fix.
07-26-2011 03:48 AM
Although now when I unpark a call I only get one way audio from the extension to the external caller, not from external to internal!
07-26-2011 07:52 AM
Hi Simon,
SIP messaging varies from SIP provider to provider. We will want to take a look at this. Can you please enable logging for your SIP trunk (Status->Support Tools), make the problem call, capture the logs and open a case with the SBCS?
Chris
07-26-2011 08:02 AM
so, do we have to start with the upgrade first then add pmf file or the other way around?
07-26-2011 08:13 AM
Hi blueshcis20,
First load the PMF file on your UC320W, at which point, the cloud will begin to offer 2.0.13_2 as an upgrade firmware. Then you can install from the cloud or download the firmware image to a local machine, and upgrade the UC320Ws firmware at your leisure.
Cheers,
Julio
07-26-2011 08:13 AM
The PMF file gives you the ability to upgrade to the 2.0.13(2) firmware release. Without it installed you won't see it as an upgrade option. So, install PMF, then upgrade.
Chris
07-27-2011 10:27 AM
Anyone who has done the upgrade can you tell me how long it took for the entire process? Obviously internet speed makes a difference but just a rough idea would be good.
07-27-2011 01:40 PM
OK Iwaited an hour and a half, came back but not updated. Retried, with no luck. On the phone with support but they can't get access to the code file so I can try to update it locally. Discovered the DSL connection is pretty slow here, not sure if that's why the update is failing or if there is something more..
Anyone else have any experience with the update not completing?
07-27-2011 01:47 PM
Hi David,
It's a large file ~60MB. Can you provide your UC320W WAN MAC address (found on the label on the bottom of the unit) and we'll have an engineer look at the Cloud Server logs?
Chris
07-27-2011 02:40 PM
I installed the update to our own system and it took about 10 minutes to download, install, reboot, then reapply the configuration. The thing that troubles me with each update is that a couple SPA525G2 phones will never update... I have to unplug them from where they are located (on a gigabit switch, non-cisco) and move them to the room with the UC320W, plug them in directly, and boom, they update.
Otherwise, everything went well, and the phone system is working well.
An unintentional bonus: Priror to this update, when I would dial by not lifting the handset on an SPA525G2 phone, dial 9xxxxxxx in a rapid fashion, sometimes the first key hit would be missed. No more problem there.
07-27-2011 05:27 PM
Hi John,
You shouldn't see this sort of behavior. If you could share a little more info about the network, it might help understand what is happening:
Chris
08-01-2011 06:54 AM
Christopher, sorry for the slow reply, been involved in a project that had me 100% absorbed for a while....
