CCA out of band guide needed
tknapp
Joseph Chambers
Don't think Cisco will be publishing one since CLI support is no longer an option for 540 and 560s.
Hi Joe, team;
Would like to add a small clarification. We don't plan to publish OOB documents anylonger, as we don't support mixed environments. i.e. you can get CCA or CLI support under the following scenarios:
  1. Start configuration on CCA and keep it within CCA: Support will be provided inside CCA boundaries
  2. Start configuration on CCA and perform additional configuration on CLI: Support will be provided on CLI, and any further config change should be performed with CLI (no warranty of OOB rules to work or to have forward compatibility).
  3. Start configuration with CLI (and stay with CLI): Support will be provided on CLI.
In order to get CLI support, you should demostrate CLI knowledge, via a UC specialization (UC Express or UC Advanced). Note this may be enforced if you don't demostrate enough CLI knowledge.
Alberto
