Fast Busy when Picking up Phone
rowseyba1
I have a UC520 that intermittantly gives a fast busy signal when picking up a phone to make a call.  It will clear, then happen again.  I have reset the box several times, but the issue comes back.  Any ideas?
I have seen a problem in the past that exhibited this symptom. In that case, the UC500 had a bug where the CPU would get pegged at 100% due to problems with the HTTP server process. You can try to issue a "show process cpu" and see what that shows. The latest releases should have corrected that.
Marcos
