Jabber support on UC500
yiqinc2004
Wanted to know whether UC500 series products support Jabber clients. Have been looking into the forums but getting conflicting information.
If you have any document link do share with me. Thanks!
UC500 support Iphone jabber client. For more information please check the following links:
https://supportforums.cisco.com/docs/DOC-24508
http://www.cisco.com/en/US/docs/net_mgmt/cisco_configuration_assistant/version3_2_1/release/Notes/cca_3_2_1_relnotes.html#wp322108
HTH,
Alex
*Please rate helpful posts
Please, I need a clarification here - Cisco no longer supports Jabber for the iPhone over 3G/4G to a UC540? My understanding was that this would work on the iphone with the Jabber client and Cisco AnyConnect VPN connected via SSL VPN to an ASA5505 (with the proper SSL and Mobile licenses installed).
Does anyone have this working reliably?
Thanks!
tracy
bkwon
yes, we support the scenario you mentioning, " iphone with the Jabber client and Cisco AnyConnect VPN connected via SSL VPN to an ASA5505 (with the proper SSL and Mobile licenses installed)."
but direct SSL VPN to UC500 is not supported.
for configuration, please refering to ASA5505 manual
