register IPHONE with UC540 - SIP "internal server error"
Michael Hamann
I am trying to setup an iphone as mobile phone device together with a SMB UC540 system. the System has the newest IOS installed (Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(4)M4b). Normal telephony with several 7965 und 7945 works without problems.
Now our customers wants to use his IPhone as a phone device. So we configured the UC540 according to http://www.ccierants.com/2011/05/finally-cisco-mobile-81-supports-cme-86.html the customer installed Cisco Jabber (since Cisco Mobile 8.1 is not available anymore) and entered Device ID, TFP Server and username/pw....
The configuration (parts of it) on the UC450 looks like this:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  bind control source-interface BVI100
  bind media source-interface BVI100
  registrar server expires max 1200 min 300
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register global
mode cme
source-address 172.19.15.1 port 5060
max-dn 10
max-pool 10
authenticate register
hold-alert
tftp-path flash:
create profile sync 0204580672223416
voice register dn  1
number 25
call-forward b2bua busy 88
call-forward b2bua noan 88 timeout 20
call-forward b2bua unregistered 88
name Michael Hamann
no-reg
label 25
voice register pool  1
registration-timer max 720 min 660
id mac 1234.5678.9100
session-transport tcp
type CiscoMobile-iOS
number 1 dn 1
dtmf-relay rtp-nte
username hamann password 12345
codec g711ulaw
The IP interfaces look like this:
UC540#show ip int brief
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES NVRAM  administratively down down
In0/0                      172.19.16.2     YES unset  up                    up
Vlan1                      unassigned      YES unset  up                    up
Vlan100                    unassigned      YES unset  up                    up
NVI0                       unassigned      NO  unset  up                    up
BVI1                       192.168.200.91  YES NVRAM  up                    up
BVI100                     172.19.15.1     YES NVRAM  up                    up
Loopback0                  172.19.16.2     YES NVRAM  up                    up
the tftp Server is bound to BVI100. A debug shows that the IPhone reaches the tftp server and gets his configuration file. But when the phone tries to register via SIP I get the following debug messages (debug ccsip messages):
001981: Sep 13 06:27:53.434: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 192.168.220.5:59997;branch=z9hG4bK57e47025
From: <sip:25@172.19.15.1>;tag=000000000000001728568569-4850c52f
To: <sip:25@172.19.15.1>
Date: Thu, 13 Sep 2012 06:27:53 GMT
Call-ID: 00000000-0000000b-3838095b-66ee5232@192.168.220.5
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 129 REGISTER
Content-Length: 0
001982: Sep 13 06:27:53.482: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
To: <sip:25@172.19.15.1>;tag=1D19CF30-CD5
CSeq: 129 REGISTER
Content-Length: 0
001983: Sep 13 06:27:53.482: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/TCP 192.168.220.5:59997;branch=z9hG4bK2ec1b5c0
To: <sip:25@172.19.15.1>;tag=1D19CF2C-738
CSeq: 128 REGISTER
WWW-Authenticate: Digest realm="bitconsulting",nonce="ACBAE8F002E8FB1E",algorithm=MD5,qop="auth"
Content-Length: 0
001984: Sep 13 06:27:58.110: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REFER sip:172.19.15.1 SIP/2.0
Via: SIP/2.0/TCP 192.168.220.5:60000;branch=z9hG4bK4da4a08d
From: <sip:000000000000@192.168.220.5>;tag=000000000000001815e09326-4adcaf02
To: <sip:172.19.15.1>
Call-ID: 00000000-0000000d-5e65d2b3-6eec162f@192.168.220.5
Date: Thu, 13 Sep 2012 06:27:57 GMT
CSeq: 1000 REFER
User-Agent: Cisco-SIPIPCommunicator/9.2.1
Expires: 10
Max-Forwards: 0
Contact: <sip:000000000000@192.168.220.5:60000>
Require: norefersub
Referred-By: <sip:000000000000@192.168.220.5>
Refer-To: cid:7328b0cd@192.168.220.5
Content-Id: <7328b0cd@192.168.220.5>
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE
Content-Length: 1297
Content-Type: application/x-cisco-alarm+xml
Content-Disposition: session;handling=required
<?xml version="1.0" encoding="UTF-8" ?>
<x-cisco-alarm>
<Alarm Name="LastOutOfServiceInformation">
<ParameterList>
<String name="DeviceName">SEP123456789100</String>
<String name="DeviceIPv4Address">192.168.220.5 / 0</String>
<String name="IPv4DefaultGateway">0.0.0.0</String>
<String name="DeviceIPv6Address"></String>
<String name="IPv6DefaultGateway"></String>
<String name="ModelNumber">SIPIPCommunicator</String>
<String name="NeighborIPv4Address"></String>
<String name="NeighborIPv6Address"></String>
<String name="NeighborDeviceID"></String>
<String name="NeighborIPortID"></String>
<Enum name="DHCPv4Status">0</Enum>
<Enum name="DHCPv6Status">3</Enum>
<Enum name="TFTPCfgStatus">0</Enum>
<Enum name="DNSStatusUnifiedCM1">4</Enum>
<Enum name="DNSStatusUnifiedCM2">3</Enum>
<Enum name="DNSStatusUnifiedCM3">3</Enum>
<String name="VoiceVLAN">0</String>
<String name="UnifiedCMIPAddress">172.19.15.1</String>
<String name="LocalPort">59997</String>
<String name="TimeStamp">1347517674</String>
<Enum name="ReasonForOutOfService">14</Enum>
<String name="LastProtocolEventSent">Sent:REGISTER sip:172.19.15.1 SIP/2.0  Cseq:130 REGISTER CallId:00000000-0000000b-3838095b-66ee5232@192.168.220.5</String>
<String name="LastProtocolEventReceived"></String>
</ParameterList>
</Alarm>
</x-cisco-alarm>
001985: Sep 13 06:27:58.114: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 400 Bad Request
To: <sip:172.19.15.1>;tag=1D19E17C-2014
Date: Thu, 13 Sep 2012 06:27:58 GMT
CSeq: 1000 REFER
Content-Length: 0
Contact: <sip:172.19.15.1:5060;transport=tcp>
001986: Sep 13 06:28:02.974: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 192.168.220.5:60000;branch=z9hG4bK19a3abb4
From: <sip:25@172.19.15.1>;tag=00000000000000190dd65e0e-74b8f03a
Call-ID: 00000000-0000000c-746f9dcb-4be0b625@192.168.220.5
Max-Forwards: 70
CSeq: 131 REGISTER
Contact: <sip:25@192.168.220.5:60000;transport=tcp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-000000000000>";+sip.instance="<urn:uuid:00000000-0000-0000-0000-000000000000>";+u.sip!devicename.ccm.cisco.com="SEP123456789100";+u.sip!model.ccm.cisco.com="30016"
Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.2.0
Reason: SIP;cause=200;text="cisco-alarm:25 Name=SEP123456789100 ActiveLoad= InactiveLoad= Last=initialized"
Expires: 3600
Content-Type: multipart/mixed; boundary=uniqueBoundary
Mime-Version: 1.0
Content-Length: 1099
--uniqueBoundary
Content-Type: application/x-cisco-remotecc-request+xml
Content-Disposition: session;handling=optional
<?xml version="1.0" encoding="UTF-8"?>
<x-cisco-remotecc-request>
<bulkregisterreq>
<contact all="true">
<register></register>
</contact>
</bulkregisterreq>
</x-cisco-remotecc-request>
--uniqueBoundary
  <optionsind>
    <combine max="6">
      <remotecc>
        <status></status>
      </remotecc>
      <service-control></service-control>
    </combine>
    <dialog usage="hook status">
      <unot></unot>
      <sub></sub>
    </dialog>
    <dialog usage="shared line">
      <unot></unot>
      <sub></sub>
    </dialog>
    <presence usage="blf speed dial">
      <unot></unot>
      <sub></sub>
    </presence>
    <joinreq></joinreq>
    <cfwdall-anyline></cfwdall-anyline>
    <coaching></coaching>
    <oosalarm></oosalarm>
  </optionsind>
--uniqueBoundary--
001987: Sep 13 06:28:02.978: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 192.168.220.5:60000;branch=z9hG4bK03d2cb5c
Max-Forwards: 70
Date: Thu, 13 Sep 2012 06:28:01 GMT
CSeq: 132 REGISTER
Content-Length: 0
Expires: 0
001988: Sep 13 06:28:02.986: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 13 Sep 2012 06:28:02 GMT
CSeq: 131 REGISTER
Content-Length: 0
001989: Sep 13 06:28:02.986: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 132 REGISTER
Content-Length: 0
001990: Sep 13 06:28:03.034: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:25@172.19.15.1>;tag=1D19F480-6AD
CSeq: 132 REGISTER
Content-Length: 0
001991: Sep 13 06:28:03.034: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:25@172.19.15.1>;tag=1D19F47C-26F
CSeq: 131 REGISTER
WWW-Authenticate: Digest realm="bitconsulting",nonce="F915D05E02E8FED9",algorithm=MD5,qop="auth"
Content-Length: 0
So the phone tries to register via SIP and stops with an internal server error.
There are no ACLs in the system, no firewall between the IPhone and the UC system... I tried diferent settings also used the Cisco Mobile 8.0 client without succes... On the phone username is set to "hamann" password is "12345"...
On a lab system with same IOS the same IPhone it works like a charm....
Any hints ?
Thank you
Michael
6 Replies 6
paolo bevilacqua
configure
athenticate real
ans username to be same as extension no.
I added
authenticate realm xxx.local
and changed the username on both sides (uc540 + iphone)
username 25 password 12345
but still no luck :-(
002027: Sep 14 08:24:06.163: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 192.168.220.5:61266;branch=z9hG4bK2d81c8c5
To: <25>
Call-ID: 00000000-00000003-17733ed4-0f21dc53@192.168.220.5
Max-Forwards: 70
Date: Fri, 14 Sep 2012 08:24:06 GMT
CSeq: 105 REGISTER
Contact: <25>;+sip.instance="";+sip.instance="";+u.sip!devicename.ccm.cisco.com="SEP123456789100";+u.sip!model.ccm.cisco.com="30016"
Content-Length: 0
Expires: 0
002028: Sep 14 08:24:06.167: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 192.168.220.5:61266;branch=z9hG4bK3e7fa271
To: <25>
CSeq: 104 REGISTER
Content-Length: 0
002029: Sep 14 08:24:06.167: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: <25>
CSeq: 105 REGISTER
Content-Length: 0
002030: Sep 14 08:24:06.219: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <25>;tag=22AA86CC-433
CSeq: 105 REGISTER
Content-Length: 0
002031: Sep 14 08:24:06.219: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <25>;tag=22AA86C8-1D17
CSeq: 104 REGISTER
WWW-Authenticate: Digest realm="xxx.local",nonce="F8D8565C037773E1",algorithm=MD5,qop="auth"
Content-Length: 0
002032: Sep 14 08:24:10.727: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/TCP 192.168.220.5:61271;branch=z9hG4bK1b786d5c
From: <000000000000>;tag=0000000000000005736ac118-65ab49da
To: <172.19.15.1>
Call-ID: 00000000-00000003-507dbb5b-6e977ca5@192.168.220.5
Date: Fri, 14 Sep 2012 08:24:10 GMT
CSeq: 1000 REFER
Expires: 10
Max-Forwards: 0
Contact: <000000000000>
Require: norefersub
Referred-By: <000000000000>
Refer-To: cid:7f53c11a@192.168.220.5
Content-Id: <7f53c11a@192.168.220.5>
SEP123456789100
192.168.220.5 / 0
0.0.0.0
SIPIPCommunicator
61266
1347611048
14
Sent:REGISTER sip:172.19.15.1 SIP/2.0  Cseq:106 REGISTER CallId:00000000-00000003-17733ed4-0f21dc53@192.168.220.5
002033: Sep 14 08:24:10.731: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
nSIP/2.0 400 Bad Request
To: <172.19.15.1>;tag=22AA98A4-1CC
CSeq: 1000 REFER
Content-Length: 0
Contact: <172.19.15.1:5060>
Do you have?
voice service voip
sip
  registrar server
yes I have
voice service voip
sip
  no update-callerid
It seem like a problem with the Mobile app, because it fails to request authenticated registration once CME asks for that and sends realm and nonce.
That is beside the internal server error, that is not normal but it doesn't seem to affect the client directly.
Hello Michael,
Did you try to follow this document:
https://supportforums.cisco.com/docs/DOC-24508
and remove the following from your config:
You may use the wifi voice vlan as the setup is flawless.
HTH,
Alex
