06-24-2014 05:52 PM - edited 03-21-2019 08:17 AM
Provisioning a new set of spa504G phones. I've always used
for spa504G.cfg, the phone finds it. I've always used:
<flat-profile>
<Resync_On_Reset>Yes</Resync_On_Reset>
<Resync_Periodic>3600</Resync_Periodic>
<Profile_Rule>tftp://ipaddress/xml/spa$MA.xml</Profile_Rule>
</flat-profile>
The new set of phones weren't provisioning, so I ran a tcpdump on the tftpserver. Sure enough, for the first time ever, the phones are looking for:
spae8:ed:f3:6b:48:b2.xml instead of spae8edf36b48b2.xml. I copied the xml to use colons and sure enough the phone provisioned and connected to my pbx.
So... how do I make it stop doing this? This is a tragedy, you have no idea how difficult it will be to get more spa phones at this point.
A bit more info:
I also tried <Profile_Rule>tftp://ipaddress/xml/spa$MAC.xml</Profile_Rule> in the initial config file.
The phones came with firmware 7.5.2 and I always upgrade to 7.5.3 using:
<Upgrade_Rule ua="na">($SWVER ne 7.5.3)? tftp://ipaddress/sw/spa50x-30x-7-5-3.bin</Upgrade_Rule>
however, this time it's not upgrading, either.
Any ideas? Anyone else seen this before? How can I make it stop, using special characters in the filename is not going to work for me.
Solved! Go to Solution.
06-25-2014 04:53 PM
<Profile_Rule>tftp://ipaddress/xml/spa$MA.xml</Profile_Rule> the phones are looking for: spae8:ed:f3:6b:48:b2.xml instead of spae8edf36b48b2.xml
Well, the $MA macro should expand to MAC with no colons. And it work this way on all firmware versions I meet. So unless it's a bug specific to 7.5.2 version, it should work. I can't test this particular case as I have no phone with 7.5.2 firmware.
The phones came with firmware 7.5.2 and I always upgrade to 7.5.3 using: <Upgrade_Rule ua="na">($SWVER ne 7.5.3)? tftp://ipaddress/sw/spa50x-30x-7-5-3.bin</Upgrade_Rule>
Wrong. It's not possible to upgrade pre-7.5.2b version to post-7.5.2b version directly. You should upgrade to 7.5.2b first. Read release notes. Also, you should consider upgrade to latest (7.5.6) version rather than to somewhat ancient 7.5.3.
Mark thread as answered if it answered your questions. It will help others to found solutions.
06-25-2014 04:53 PM
