02-16-2010 04:17 AM - edited 03-21-2019 02:10 AM
I have several SPA504G IP Phones connected to a UC520. When you scoll through the call history of placed calls, some entries are missing the leading 9 required to redial the number. The 7945 does not have this problem. Is there a fix?
Also all phones fail to display the leading 90 when displaying received calls and missed calls. Is there a setup option for this?
Solved! Go to Solution.
02-16-2010 08:07 AM
Your first issue seems to point ot a difference in how we process outbound calls that go through a translation rule. We will look into this.
Your second issue is discussed at length in other threads on this community, for example:
https://www.myciscocommunity.com/message/6010
Marcos
02-16-2010 03:39 PM
I used CLI to get translation rules that would append a 9 to the originating number, but CCA 2.2 appears to not recognize the custom translation rules, even though the dialplan only has a few differences from a CCA-configured dialplan. CCA should be updated to allow this kind of translation.
Here are the changes from the standard CCA-configured dialplan to get this configuration (with the changes from the CCA-configured dial plan indicated in red):
voice translation-rule 100
rule 1 /^\+?1/ /9/
rule 2 /^\([2-9][0-9][0-9][2-9][0-9][0-9][0-9][0-9][0-9][0-9]\)$/ /9\1/
rule 3 /^\+\([2-9]\)/ /9011\1/
rule 4 /^011\([2-9]\)/ /9011\1/
! Here are voice translation profiles used for inbound calls
! (with the changes from a CCA-configured dialplan in red)
voice translation-profile DID_Called_1
translate called 1
translate calling 100
voice translation-rule DID_Called_2
translate called 2
voice translation-profile DID_Called_3
translate called 3
voice translation-profile DID_Called_4
translate called 4
voice translation-profile TRANSLATE_INCOMING_CALLING
02-16-2010 08:07 AM
Marcos
02-16-2010 03:10 PM
Could you provide your config for the phones? I am not aware of this problem. Are the calls that are missing the 9 edited dial numbers?
I am not sure why the phones would be missing a leading 90. Does the 7945 have this work? This could be a bad translation rule.
02-16-2010 03:39 PM
rule 1 /^\+?1/ /9/
translate called 1
translate called 2
translate called 3
translate called 4
02-17-2010 02:49 PM
The 9 missing sometimes from the dialled numbers history is only happening on my SPA504G phones.
All the phones have 90 missing from the missed calls and received calls history.
This means that the numbers have to be edited before they can be dialled.
02-22-2010 02:15 PM
CLI addition required to align directory numbers and missed and received call numbers by adding 90 to all incoming caller IDs: additions in red voice translation-rule 100rule 1 /^/ /90/!voice translation-profile BasicConnectALL_Called_12translate calling 100translate called 12!voice translation-profile BasicConnectALL_Called_15translate calling 100translate called 15!voice translation-profile MainNumber-AA_Called_10translate calling 100translate called 10
Many thanks John
03-04-2010 08:12 AM
Now that I've ironed out the call history problems on "Missed Calls" and "Received Calls", I now have one hard fault with "Placed Calls" which just occurs on the SPA504G. When you place an outside call with a "9" no the front, this 9 does not appear afterwards in the "Placed Calls" call history. This problem does not occur on the 7945. Both phones are fitted to a UC520. Any ideas how to cure this problem on the SPA504G??
03-04-2010 11:10 AM
I don't believe that this is a configuration issue on the placed calls. It sounds like a bug in the phone firmware. Would you mind opening a case for this? Give me the case number when you do so that I can track it.
03-04-2010 03:26 PM
Sorry, but my login ID does not have the required access to Create a TAC.Service Request.
03-06-2010 12:32 AM
Hello, I have the same problem (entries in the placed call list miss the digit 0 to dial out) with all SPA508 phones at a customers site. All Cp7965 phones at the customers site are working correctly.
05-06-2010 08:57 AM
Did you find a solution do this problem? I have the same issue, SPA phones do not have the '9' prepended for placed calls, recieved and missed is fine. 79xx phones have the 9.
05-06-2010 02:32 PM
As suggested by Steven, a case is needed here.
marcos
05-07-2010 03:41 AM
TAC = SR 613949243 - SPA500 - call history missing line prefix
05-07-2010 03:42 AM
03-04-2010 10:42 AM
Still a problem.
