the double hook flash problem is still an annoying issue with the 5.1.10 code, I wonder if Cisco has any plans to fix the problem anytime soon
Hi all,I might be possibly falling into a scenario where I might have to quote a UC560 with the ability to support between 10 and 14 analog (FXO)...is this possible and what would I need to make it work?
guys,how do you integrate linksys small business product (srw224g4p) with uc560?i have tried to create muliple vlans (data and voice) on the switch, but it's not getting voice vlan. uc 560 is still running default ip.any ideas?thank you
Hi,i have a problem with wrp400 fw205.All the network is in pppoe and sometimes happen that wrp400 continuus disconnect.On my radius i see this error: 304 Fri Apr 9 07:45:11 2010 : Error: [sql] stop packet with zero session length. 305 Fri Apr...
Have another issue where certain FXOs just lock up. The LEDs on the UC shows an active call but there isn't one. Port sum shows weird statues - I'm trying to find my debug logs. I have to shut / unshut the FXO so that calls can go through. I have o...
I am using SB voice system - SPA9000, SPA400 & SPA9xx in Saudi Arabia. I am having caller ID problem, it does not display the correct number or only part of it is correct or Anonymous caller.Sometimes it is difficult to even guess the number and cant...
Hi teams,I have a hunt group with two extension.Using this hunt group i handled the call successfully.Now i created new voice mail box with no 850.Now i wanted to divert the call to this voice mail if any can not picking the phone.My voice mail pilot...
Hello everyone. I´m having some issues on uc520.IP Phones 521s can´t register, on the display shows " SPCP Register Token Rejected" but if a configure this phones as a 524g phone, it works. but in this case the Pc port,is disabled.Plus ,trying to ac...
Hi,I have a UC520 with a B-ACD group configured with CCA 2.2.1. When you call the pilot, you receive dead air then a busy signal after a bit. I've done some debugging, and the correct dial-peer is being reached. What debug commands can I use to ge...
Hi all,I would like you to ask for help with setting SPA8000.I have bought SPA8000 witch firmaware 6.1.3.Between SPA800 and PBU (PhoNET) is SIP TRUNK (I use TRUNK GROUPS T1).How to set L1 to L8 to have similar features as inner extension ?For example...
Hi,I have a problem with 7962/7915 set. The 7915 lost its connection when power cycled after working for several months. All lights on it stay orange now. I found that the firmware for both parts are not on the UC520. I moved the 7915 to another 7962...
I don't suppose you can help me out with UK PRI (ISDN30) settings?I've set it as an E1 ISDN30 Primary NET5. There is then an option for Bearer Capability that I can't find a standard setting for.CD light comes on next to the PRI port, but incoming ca...
i have attached an example.Hi,We are a Cisco partner and have recently installed a UC500 system running call manager express for one of our clients. The client requires reporting for this system and we have been working with OAK to provide the requir...
Hello, I have a video intercom connected to an IP spa 9000 with 3 pc (x-lite installed) the SIP while everything is working correctly, I would like added to a SPA3102 to dial a number if no one answers the intercom. To know that I have no account wit...
Hey guys,I have a customer that is one step away from purchasing several UC540s with ESW switches but are wondering specifically if these items are FIPS 140 compliant. Can anybody speak to this?thanks,Seth
