spa942 sending bye message after answering the call
etxnreg
Have an issue that I can't fin the reason for.
We have 10 spa942 phones.
Some time the phones sending a bye message directly after you have answer the call.
It happens approx 5 of 100 incoming calls.
Has someone any clue why?
Could it be any parameters?
I'm desperate.....
Thanks Niklas
5 Replies 5
rvaltier
Hi Niklas
Per your description seems to be related to a codec negotiation issue, it could be that sometimes your are receiving a mismatch signaling.
A ethereal trace over a phone could help to find the root of this issue. could you get one?
Rogelio V.
Here is a trace.
Grateful for any help
//Niklas
input: sip_03880_20110411035342.pcap
match: 4166325e-be1d174-148e50d6-26b3@sip-gw.abc.net
U 2011/04/11 08:27:40.203539 w.w.w.w:5060 -> q.q.q.q:5060
INVITE sip:222222222@ser.srv.ip-only.net;user=phone SIP/2.0.
Via: SIP/2.0/UDP sip-gw.abc.net:5060 ;branch=z9hG4bKterm-41f717-111111111-222222222-10839.
From: 111111111 <>111111111@sip-gw.abc.net;user=phone>;tag=813571214.
To: 222222222 <>222222222@ser.srv.ip-only.net;user=phone>.
Call-ID: 4166325e-be1d174-148e50d6-26b3@sip-gw.abc.net.
CSeq: 1 INVITE.
Supported: timer, 100rel.
Session-Expires: 1800.
Min-SE: 1800.
Contact: <>111111111@sip-gw.abc.net:5060>.
Allow: INVITE,ACK,PRACK,SUBSCRIBE,BYE,CANCEL,NOTIFY,INFO,REFER,UPDATE.
Max-Forwards: 15.
Content-Type: application/sdp.
Content-Length: 677.
v=0.
o=- 49181129 0 IN IP4 213.132.106.6.
s=Cisco SDP 0.
c=IN IP4 213.132.106.6.
t=0 0.
m=audio 19764 RTP/AVP 8 0 18 99 102 103 104 105 4 106 107 108 109 125 101 100.
a=rtpmap:99 G.729a/8000.
a=rtpmap:102 G.726-16/8000.
a=rtpmap:103 G.726-24/8000.
a=rtpmap:104 G.726-32/8000.
a=rtpmap:105 G.723.1-H/8000.
a=rtpmap:106 G.723.1-L/8000.
a=rtpmap:107 G.729b/8000.
a=rtpmap:108 G.723.1a-H/8000.
a=rtpmap:109 G.723.1a-L/8000.
a=rtpmap:125 G.nX64/8000.
a=rtpmap:101 telephone-event/8000.
a=fmtp:101 0-15.
a=rtpmap:100 X-NSE/8000.
a=fmtp:100 200-202.
a=X-sqn:0.
a=X-cap: 1 audio RTP/AVP 100.
a=X-cpar: a=rtpmap:100 X-NSE/8000.
a=X-cpar: a=fmtp:100 200-202.
a=X-cap: 2 image udptl t38.
U 2011/04/11 08:27:40.205330 q.q.q.q:5060 -> w.w.w.w:5060
SIP/2.0 100 Trying.
Via: SIP/2.0/UDP sip-gw.abc.net:5060 ;branch=z9hG4bKterm-41f717-111111111-222222222-10839;received=w.w.w.w.
CSeq: 1 INVITE.
Server: Kamailio at IP-Only.
Content-Length: 0.
U 2011/04/11 08:27:40.205390 q.q.q.q:5060 -> x.x.x.x:5060
INVITE sip:222222222@sip.goldenpartner.se:5060;user=phone SIP/2.0.
Record-Route: .
Via: SIP/2.0/UDP q.q.q.q;branch=z9hG4bK55f5.e2fa58e51f10a286409407c6af4f726a.0.
Via: SIP/2.0/UDP sip-gw.abc.net:5060 ;received=w.w.w.w;branch=z9hG4bKterm-41f717-111111111-222222222-10839.
CSeq: 1 INVITE.
Min-SE: 1800.
Max-Forwards: 14.
v=0.
s=Cisco SDP 0.
t=0 0.
a=fmtp:101 0-15.
a=fmtp:100 200-202.
a=X-sqn:0.
a=X-cap: 2 i
U 2011/04/11 08:27:40.215411 x.x.x.x:5060 -> q.q.q.q:5060
SIP/2.0 100 Trying.
Call-Id: 4166325e-be1d174-148e50d6-26b3@sip-gw.abc.net.
Cseq: 1 INVITE.
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.550615 x.x.x.x:5060 -> q.q.q.q:5060
SIP/2.0 180 Ringing.
To: 222222222 <>222222222@ser.srv.ip-only.net;user=phone>;tag=63b35332bbcf3f3ei1.
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Contact: "4640473444" <4640473444>.
Server: Linksys/SPA942-6.1.5(a).
Content-Length: 0.
Date: Mon, 11 Apr 2011 06:27:40 GMT.
U 2011/04/11 08:27:40.550720 q.q.q.q:5060 -> w.w.w.w:5060
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.555816 x.x.x.x:5060 -> q.q.q.q:5060
To: 222222222 <>222222222@ser.srv.ip-only.net;user=phone>;tag=c61d0ed73686e326i1.
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.555892 q.q.q.q:5060 -> w.w.w.w:5060
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.564996 x.x.x.x:5060 -> q.q.q.q:5060
To: 222222222 <>222222222@ser.srv.ip-only.net;user=phone>;tag=745321ed8e5a125ei1.
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.565068 q.q.q.q:5060 -> w.w.w.w:5060
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.585841 x.x.x.x:5060 -> q.q.q.q:5060
To: 222222222 <>222222222@ser.srv.ip-only.net;user=phone>;tag=665182f945118c6fi1.
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.585945 q.q.q.q:5060 -> w.w.w.w:5060
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.588840 x.x.x.x:5060 -> q.q.q.q:5060
To: 222222222 <>222222222@ser.srv.ip-only.net;user=phone>;tag=c74a413c6928986bi1.
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.588902 q.q.q.q:5060 -> w.w.w.w:5060
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.600070 x.x.x.x:5060 -> q.q.q.q:5060
To: 222222222 <>222222222@ser.srv.ip-only.net;user=phone>;tag=cdc1a45a86fd0040i1.
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.600142 q.q.q.q:5060 -> w.w.w.w:5060
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.608719 x.x.x.x:5060 -> q.q.q.q:5060
To: 222222222 <>222222222@ser.srv.ip-only.net;user=phone>;tag=b192acc0d2fb6b20i1.
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.608810 q.q.q.q:5060 -> w.w.w.w:5060
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.631797 x.x.x.x:5060 -> q.q.q.q:5060
To: 222222222 <>222222222@ser.srv.ip-only.net;user=phone>;tag=fb29a22766562bd9i1.
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.631868 q.q.q.q:5060 -> w.w.w.w:5060
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.643200 x.x.x.x:5060 -> q.q.q.q:5060
To: 222222222 <>222222222@ser.srv.ip-only.net;user=phone>;tag=1a421a3c4e6ae62bi1.
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:40.643315 q.q.q.q:5060 -> w.w.w.w:5060
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 0.
U 2011/04/11 08:27:46.869044 x.x.x.x:5060 -> q.q.q.q:5060
SIP/2.0 200 OK.
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
Content-Length: 216.
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER.
Supported: replaces.
Date: Mon, 11 Apr 2011 06:27:46 GMT.
v=0.
o=- 379194709 379194709 IN IP4 192.168.84.202.
s=-.
c=IN IP4 y.y.y.y.
t=0 0.
m=audio 16422 RTP/AVP 8 101.
a=rtpmap:8 PCMA/8000.
a=fmtp:101 0-15.
a=ptime:20.
a=sendrecv.
U 2011/04/11 08:27:46.869653 q.q.q.q:5060 -> w.w.w.w:5060
SIP/2.0 200 OK.
Cseq: 1 INVITE.
Record-Route: .
Record-Route: .
v=0.
s=-.
c=IN IP4 y.y.y.y.
t=0 0.
a=fmtp:101 0-15.
a=ptime:20.
a=sendrecv.
U 2011/04/11 08:27:46.885205 w.w.w.w:5060 -> q.q.q.q:5060
ACK sip:q.q.q.q;lr=on;ftag=813571214;d=332.ee42dd67 SIP/2.0.
Via: SIP/2.0/UDP sip-gw.abc.net:5060 ;branch=z9hG4bKterm-41f717-111111111-222222222-8444.
CSeq: 1 ACK.
Route: ,"4640473444" <4640473444>.
Content-Length: 0.
U 2011/04/11 08:27:46.885891 q.q.q.q:5060 -> x.x.x.x:5060
ACK sip:4640473444@y.y.y.y:5082 SIP/2.0.
Max-Forwards: 10.
Record-Route: .
Via: SIP/2.0/UDP q.q.q.q;branch=z9hG4bK55f5.4c46cf17d30c0ab748571b4bca786f9a.0.
Via: SIP/2.0/UDP sip-gw.abc.net:5060 ;received=w.w.w.w;branch=z9hG4bKterm-41f717-111111111-222222222-8444.
CSeq: 1 ACK.
Route: .
Content-Length: 0.
U 2011/04/11 08:27:46.918232 x.x.x.x:5060 -> q.q.q.q:5060
BYE sip:111111111@sip-gw.abc.net:5060;x-sipX-nonat SIP/2.0.
Route: .
Via: SIP/2.0/UDP x.x.x.x;branch=z9hG4bK-XX-aad2YHAIMKACtiK2YADOjY1qrA.
Via: SIP/2.0/UDP y.y.y.y:5082;branch=z9hG4bK-29822e00.
From: "222222222" <>222222222@ser.srv.ip-only.net;user=phone>;tag=fb29a22766562bd9i1.
To: "111111111" <>111111111@sip-gw.abc.net;user=phone>;tag=813571214.
Cseq: 101 BYE.
Max-Forwards: 20.
User-Agent: Linksys/SPA942-6.1.5(a).
Content-Length: 0.
U 2011/04/11 08:27:46.918799 q.q.q.q:5060 -> w.w.w.w:5060
Record-Route: .
Via: SIP/2.0/UDP q.q.q.q;branch=z9hG4bK1fd7.e840b11fa6d7201b6b6d87a9dd8f4316.0.
Cseq: 101 BYE.
Max-Forwards: 19.
Content-Length: 0.
U 2011/04/11 08:27:47.006700 w.w.w.w:5060 -> q.q.q.q:5060
SIP/2.0 200 Ok.
CSeq: 101 BYE.
Content-Length: 0.
U 2011/04/11 08:27:47.006827 q.q.q.q:5060 -> x.x.x.x:5060
SIP/2.0 200 Ok.
CSeq: 101 BYE.
Content-Length: 0.
what I saw in your trace is that phone is negotiating codec PCMA
v=0.
s=-.
c=IN IP4 y.y.y.y.
t=0 0.
a=fmtp:101 0-15.
a=ptime:20.
a=sendrecv.
And in the original invite received such codec is not included in SDP, are you forcing the phone to use PCMA as the only preferred codec?
v=0.
s=Cisco SDP 0.
t=0 0.
a=fmtp:101 0-15.
a=fmtp:100 200-202.
a=X-sqn:0.
a=X-cap: 2 i
rmvaliev
Dear Niklas
In my environment I have same problem: sometime linksys send BYE message (abount 7% of calls).
Could you say how you resolve this problem? Is Forced codec setting helped to you?
In my configuration Force LAN Codec:G711a
BR
Unfortently we did not find why we had this problem.
BR Niklas
