03-07-2011 08:38 PM - edited 03-21-2019 03:46 AM
Does SPA9xx and SPA5xx support LDAP lookups for inbound calls? If the phones supports it, what settings need to be configured for this. If not, are there any plans in the future for this feature to be supported on these phones?
Solved! Go to Solution.
03-08-2011 05:47 AM
Hi Ryan-Glenn;
The feature is currently not supported for inbound, it works for outbound only. It is not in the short term roadmap.
Alberto
03-08-2011 05:47 AM
Hi Ryan-Glenn;
Alberto
04-23-2011 03:17 AM
Ryan,
The only way I know to do this would be to use Call Ctrl which will screen pop inside Windows for all incoming phone calls. There is support for LDAP and XML shared directory. This does require the additional software, but the only way I know how to accomplish your requirement.
Steve Wofford
Call Manager for SPA IP Phones
01-10-2014 04:53 AM
This is a very good feature to add on the roadmap !
01-10-2014 05:08 AM
I have a growing fleet of 7800 cisco SPA500 and this feature will make my dream come true ^^
