04-03-2012 08:18 AM - edited 03-21-2019 05:36 AM
Hello
I'm trying to setup a FTP to collect the CDR files from the UC560 and this is the error I'm Getting
Any Help Please
04-03-2012 11:28 AM
Check your FTP server logs if it shows the access attempt and a better error code?
Also, which exact IOS / software pack are you using ?
04-03-2012 11:52 AM
Hello
Thanks for the answer, one of the main problems is we don't see any connnection in the FTP server,
UC version 8.0.6, IOS 15.1(2)T4
Thanks for your help
04-03-2012 12:54 PM
https://supportforums.cisco.com/thread/2067765
possibly a data corruption bug not filed yet.
try reloading router.
04-03-2012 01:44 PM
Hi Yency,
This is a common problem with the FTP services on the UC-500, even if you get it to work, the longest I could get it to stay up and working for is 1 week before it would respond with the exactly the same error as the one you reported.
All the mlst recent IOS revisions have had a very poorly implimented FTP service and I would go as far as to say it got worse over the last 2 years.
You need to log a case for this, its about time they took this issue serious and issued a bug on it and resolved it.
Cheers,
David.
04-03-2012 02:58 PM
Agree with David and rated.
04-04-2012 04:02 AM
Paolo / David,
if ftp is unreliable, and syslog doesn't seem to deliver all of the fields in the CDR, is RADIUS the only safe option? If so, how do I configure it using CCA?
Andy
04-04-2012 04:35 AM
You have to confirgure RADIUS via the CLI and it provides all the CDR header information.
Go here for setup information - http://www.cisco.com/en/US/docs/ios/voice/cdr/developer/guide/cdradius.html
Our TIM Plus and Enterprise call logging / accounting software have RADIUS built into the product and automatically configures the directory based on your existing Cisco configuration.
Free trials available, unlimited display boards and web users included free of charge. Visit our microsite for more information www.tri-line.com/cisco
TIM Plus overview video:
04-04-2012 06:42 AM
Thanks Jamie, but the Cisco people on here keep saying "use CCA". What I was asking - possibly not clearly enough - was if ftp not reliable, how do I configure RADIUS via CCA. I've read the doc you've linked to - extensively - and already have a database and reporting tools setup based on ftp exports of CDRs and tftp from BACD: if I've got to re-do it to use RADIUS because the ftp implementation is questionable, then I need to be able to configure RADIUS using CCA (or, alternatively, need to find UC software build with problem-free ftp that doesn't remove any other features if it's a downgrade).
Andy
04-08-2012 05:15 AM
Hi Andy,
Sorry for the late reply...
At this junction I am unable to help you any further, Simply because I don't any any answer to your problem :-(
Sorry for that.
Cheers,
David.
04-08-2012 06:37 AM
Thanks anyway David !
Will start playing with RADIUS, see how it goes.
Andy
04-09-2012 03:49 AM
abillington wrote:
Thanks Jamie, but the Cisco people on here keep saying "use CCA". What I was asking - possibly not clearly enough - was if ftp not ...
I think you should try whatever it takes to make your system work.
Cisco people (or anybody else) call say whatever they want but at the end of the day it's you having the problem, and if something can't be done one way, it has to be done another way.
