UC320 - security leak
roland.schaffer
Hi there!
I just tested this:
uc320 can be penetrated with faked icmp entries in the NAT table, which can be triggered at any time from the internet to enter the LAN behind it.
Thus, a virus can set up the faked NAT entries from "local inside", and a virus-controller can enter the LAN by triggering those false NAT-entries at "global inside" from "global outside".
Are there any plans to fix this?
regards,
Roland
6 Replies 6
kvarshne
Dear Roland
UC320 has never been sold as a robust security device. Cisco has been recommending it for easy and affordable IP PBX for very small deployment. There exists a best practice deployment guide for more secure solution. Please refer below:
http://tools.cisco.com/s2slv2/ViewDocument?docName=EXT-AS-370391
For best practices for small business security devices, refer below:
http://www.cisco.com/web/partners/sell/smb/tools_and_resources/small_business_network_foundation.html
Best regards
So its cisco's position that in a greyfield deployment this poses no security threat? Even when setup for remote administration?
Thank you
Jonathan
ha ha
Wireshark my host and UC320W:
6    0.999650000    192.168.10.11    192.168.10.1    HTTP    494    GET /admin/pbxstatus.xml?instance=&xuser=admin&xpassword=MYPASSWORD&xsession=1385551665136@@688 HTTP/1.1
MYPASSWORD - TX in open type! COOL! It's really surely and safety!
There are better security problems than that!.. You can rewrite any file on the filesystem as root fairly trivially. Especially handy for /etc/passwd..
Hi Efim,
We were aware of the vulnerability.since this only exists from the LAN side that faces the customer,we rationalized that the exposure to a "friendlier" audience from within the company was tolerable.
Nima
Insiders? no, not heard
