You really need to TAC this to be sure but i ran it anyway this is what i got back looks to be a bug
ERROR: This device has recorded 'Spurious Access', which is caused by a Cisco
IOS software bug. A spurious access occurs when a process attempts to read from
the lowest 16 KB region of memory. This portion of memory is reserved, and should
never be accessed. A read operation to this region of memory is usually caused
when a non-existing value is returned to a function in the software, when a null
pointer is passed to a function.
TRY THIS: Upgrade your device to the latest version of Cisco IOS software in your
release train. Review Bug Search Tool for any potential bugs related to the
loaded image. Paste the "show tech-support" command output into the Output Interpreter
to display the potential issues and fixes. If the issue persists, consider opening
a service request with Cisco using the TAC Service Request Tool. Include the
"show alignment" and "show tech-support" command output f
