Hi, everyone.I have a IP Phone 7942 and I would like to control the phone programmatically (NI Labview) using a PC.So kindly need any expert to advise whether that can be achieved or there is a ready driver to do so.Thanks in advance.
Hi,I have a problem with my UC320W where one of my phones (SPA303) is giving the operator a Invalid Number responce when they try to dial out. This phone is ran off a wireless bridge as are several other phone in our system. The other phones dont run...
Buenas,Los telefonos estaban funcionando normal por la web, pero a la hora de crear una vlan de voz y separarlos se ha estado teniendo problemas para ingresar a la interfaz web del telefono, no muestra la configuracion. su ayuda por favor.Gracias
HI,I am looking for a little help with this all input is welcome.I have a UC540W and a number of endpoints all are 79xx series using sccp. only one is a 9971 sip handset.I have configured the unit using the Cisco configuration assistant version 3.2, ...
Quick question, we are installing a new UC560 e1/t1 device on our company network behind our asa 5520 firewall. We are ordering a dedicated t1 line we want to run directly into the UC560. Verzion is supply us with a Adtran router for the T1. Will the...
Maybe some of you have already noticed it, firmware version 7.5.5 is available:http://software.cisco.com/download/release.html?mdfid=282724650&softwareid=282463651&release=7.5.5&relind=AVAILABLE&rellifecycle=&reltype=latestLanguage files:http://softw...
We have a UC540 deployed at a customers site. When we sold the unit last year, they had 24 users. They have recently expanded and now need 34 phones. Is the 32 phone limit a hard limit? When I run a sh ver on the UC, it says we're licensed for 3...
How can I activate Call Pick UP on an SPA504G?I have enabled the supplimentary service, and moved the "pickup" task to softkey 3 on the dialling menu, but the option does not appear on the screen. The phone is conected to a small te...
Hi. I didn't find in documentation how to solve the following problem. It is necessary to execute cisco device reset with the current active calls. Sometimes suspends the voice module, but web the interface it is thus available, the device doesn't ...
Hi,I know this has been asked already but maybe there is some progress on this problem. Client of ours needs to be able to monitor the ringing status of the phone and be able to pickup a call straight from the sitecar. Based on the below post monitor...
Hello,I have 9951 phones and I would like know how can I do for have some buttons :- Button Pickup or Pickup Group- Button Call ForwardI search in CCA "Phone Template" but there are no phone template for 9951 phones.Thank you.
So I have a couple of brand new SPA525Gs right out of the box and we are having trouble with them on the network.I've setup a sniffer capture to see what's happening and it looks like the phone sends out a dhcp request but never accepts the offer fro...
I am using a port on the SPA8000 to ring a PagePal analog paging device but having an issue getting it to disconnect. The port is set up as a SIP user on a VoIP telephone system. Fax machines and other analog devices seem to be working fine however, ...
